Announcing: Auto headlights version 2 for 997.1 & 997.2
Old 01-01-2024, 09:30 PM
  #76
iamuwere
iamuwere's Avatar
So simple and so effective.
Thanks for the very quick shipping and prompt support.
Hatzenbach (01-02-2024)
Old 01-02-2024, 12:26 AM
  #77
Boggus
Boggus's Avatar
Installed mine today, went smoothly, hardest part was running the sensor wire to be hidden in the defroster vent.
Old 01-02-2024, 03:19 PM
  #78
Hatzenbach
Hatzenbach's Avatar
Just a quick update: I was able to source the Porsche OEM connectors, which makes the installation now literally a snap (or plug&play)
Here's a link to the updated instructions.
I am also working on getting a dedicated web-site up&running. Should be done by the end of this week.
That should make ordering a bit easier. Stay tuned.....
The following 2 users liked this post by Hatzenbach:
Boggus (01-02-2024), MrMoose (01-02-2024)
Old 01-02-2024, 05:29 PM
  #79
Wepeachy
7th Gear
Wepeachy's Avatar
Wow with those connectors this is absolutely fool proof! This is still by far the best mod I've done to my 997.2 just makes one less thing to worry about, and so simple it plug and play
Old 01-04-2024, 06:08 PM
  #80
funnelofdoom
funnelofdoom's Avatar
Originally Posted by Chuckben
Am I correct in assuming that the unit will work on a 996.1?
Because the 996 has a purely mechanical switch that switches power directly to the headlights, it would be possible to do fairly easily if you're somewhat proficient in wiring up relays using a simple timer sun sensor circuit like I outlined in my $9 solution for automatic headlights (for 997). You'd simply need to check which pins are connected to which through the various switch positions. Then use the off position or side light position to power the circuit, though you might have to tap into a 12V line off the fuse box if it's ground switching. Taking a quick look at the schematic though it looks like it switches +12V (with a separate fusebox for the lighting circuit). You might need to get a secondary relay to shoot off the first relay to power multiple circuits, but maybe not depending on how things are switched. You would also probably want to wire in a simple on/off switch so you can turn off your lights if necessary (if you're taking over the OFF position or need to use the side lights alone).
OR
Simply buy a universal automatic headlight module. You wouldn't have to run wires to your lights since all the wiring is in the switch itself. It looks like you'd connect the dimmer control line (looks like an internal realy in the car to dim interior lights), the low beams, and the running lights. Modules typically control these things separately so you could even take over the parking light/side light position to use as the auto position. Most of these modules seem to also have a Park/parking brake input which triggers the headlights off in case you actually want to just use your sidelights. I'm talking about modules like this:
Amazon Link for Example Headlight Module Amazon Link for Example Headlight Module
Really actually much easier to do. I also made my own version of auto headlights for my 997 similar in concept to Hatzenbach's but one of those modules would be a much easier and foolproof solution. Toying with electronics can be buggy. Oh, and jduging by the harness used for the headlight switch, you'd either have to splice wires (not just tap) or make a custom harness of some type using barrel type connectors like this:
Amazon Link for example barrel connectors Amazon Link for example barrel connectors
EDIT:
You might evne actually be able to use one of those older VW auto headlight modules like this:
Amazon Link for Example Headlight Module (VW specific) Amazon Link for Example Headlight Module (VW specific)
. It probably has relays and a control circuit. You would just have to fit it in your car (hopefully not too big) and figure out the wiring from your car to the VW pinout. There's a good chance it would work since it looks like your car uses 12V switching, but again, I'm not 100% positive. Even then, it could still work since you're simply energizing relays.
Old 01-04-2024, 07:23 PM
  #81
Chuckben
Chuckben's Avatar
Thanks, funnelofdoom! I am going to look into this as I am an electrical engineer by training. My son and I just bought this 2000 996.1 C4 cab and we are both concerned that we will leave the lights on and run down the battery. BTW, I have just added a cable extension to the trunk manual pull wire release and located the end behind the right marker light.
Old 01-05-2024, 12:40 AM
  #82
Kuro Neko
Kuro Neko's Avatar
Received 1,695 Likes on 645 Posts
Indeed, sourcing and using the OEM-style connectors takes it up a notch.
Notably, as I tried to do similar for my Sport Chrono to regular clock mod, and must have spent weeks looking for the correct native plugs and sockets - unsuccessfully too I might add.
I've ordered the 987.2 version of this great idea, it arrived this morning (speedy!), and I will try and find the time to install this weekend.
In the meantime I can confirm our supplier here is great in comms and support.
Install pics and performance comment to follow...
Hatzenbach (01-05-2024)
Old 01-05-2024, 09:21 AM
  #83
TerrestrialFlyte
TerrestrialFlyte's Avatar
Being an early adopter, I’m kind of jealous of the OEM connectors. I have mine secured with electrical tape, but it gets HOT here in central Texas and I’ve always wondered what that adhesive does under the dash inside a sealed up car on those 100°+ days. Either way, amazing product and service. Kudos to Hatzenbach.
The following 2 users liked this post by TerrestrialFlyte:
Boggus (01-05-2024), Hatzenbach (01-05-2024)
Old 01-05-2024, 11:35 AM
  #84
Hatzenbach
Hatzenbach's Avatar
Thank You. I always knew that the Japanese are efficient, but hats off to their postal service. The package took less than a week door to door!
Old 01-05-2024, 03:56 PM
  #85
Hatzenbach
Hatzenbach's Avatar
Aaaaaaaand I'm happy to announce that my eCommerce site is finally up&running
https://www.997research.com/
It has product descriptions, FAQs, manuals, shows "work in progress", and of course has an order page.
The site is brand new, any feedback is appreciated.
The following 3 users liked this post by Hatzenbach:
apkarian100 (01-05-2024), Elliotw44 (01-05-2024), TerrestrialFlyte (01-05-2024)
Old 01-05-2024, 04:23 PM
  #86
TerrestrialFlyte
Congrats!! Any other outstanding products in the pipeline?
Old 01-05-2024, 04:34 PM
  #87
Wayne Smith
Wayne Smith's Avatar
Received 1,195 Likes on 762 Posts
Like an option for the wart?!?!?!
Old 01-05-2024, 05:12 PM
  #88
nicogri
nicogri's Avatar
Great news !
Site is Nice and clean
Do you plan to implement other payment method like PayPal in the near future ?
Old 01-05-2024, 05:30 PM
  #89
Elliotw44
Elliotw44's Avatar
Received 1,007 Likes on 418 Posts
I'd love an option for the sport chrono(wart) that it just tells time and is illuminated during vehicle operation.
Old 01-05-2024, 05:55 PM
  #90
TerrestrialFlyte
There is a wart option on the website. Looks like actual temperature gauges for coolant and maybe oil (?) instead of the dummy coolant gauge we have.
Quick Reply: Announcing: Auto headlights version 2 for 997.1 & 997.2
