Preemptively replace water pump?
Subscribe
Sep 16, 2023 | 09:38 AM
  #91
Quote: Did they explain reasoning behind avoiding the low temp thermostat?
Not his Indy, but this is what my Indy (Austin TX) advised when I asked for a quote to replace water pump and LTT:
"I would advise against a lower temperature version for street use. The lower temperature version could trigger a cooling system fault code because the engine would take longer to warm up and would no longer operate at the temperature which the software in the computer is looking for. It could also trigger catalyst efficiency fault codes depending on the driving conditions."
Reply 0
Sep 16, 2023 | 09:47 AM
  #92
Quote: Not his Indy, but this is what my Indy (Austin TX) advised when I asked for a quote to replace water pump and LLT:
Mind sharing who your Indy is? I installed it myself last year and have about 2,300 miles on it with no faults. Not that my experience is the end all, be all.
Reply 0
Sep 16, 2023 | 09:53 AM
  #93
Have 80k combined miles of my own ownership on 2 997.1s with LTTs installed a s not a single one of those codes.
There's no good reason not to do this and plenty of good reasons to do it, but you guys can do what you think is best vs what Jake and Charles have proven is best.
Reply 0
Sep 16, 2023 | 01:10 PM
  #94
I DM'd Jake directly on Facebook and asked his opinion of whether I should put a LTT in my 997.1, and his answer was 1 word - 'absolutely'.
I will have it done, regardless of my Indy's opinion. I just wanted to add that dialog to see what others opinions might be.
Now I just need to decide whether to let them do it or find someone else.
Reply 0
Sep 16, 2023 | 04:02 PM
  #95
To follow up on this thread I did replace the water pump + 160 degree thermostat. In addition I also had other stuff replaced:
Clutch
IMS replaced with LNE IMS solution (old bearing looked great)
New IMS seal
New RMS
New OEM shift cables
Oil changed for DT40
This morning I installed new motor mounts. All thats left to do is drive it a lot. Oh and probably do plugs and coils at some point - I’m not looking forward to that job.
Reply 0
Sep 16, 2023 | 04:12 PM
  #96
Quote: To follow up on this thread I did replace the water pump + 160 degree thermostat. In addition I also had other stuff replaced:
Clutch
New IMS seal
New RMS
Dang what was the damage?
Reply 0
Sep 16, 2023 | 07:28 PM
  #97
Quote: Dang what was the damage?
$7k with tax. But now I’ve pretty much covered all of the maintenance items (I did the AOS, hoses, engine mounts, alternator and battery myself). I will do plugs and brakes at a later date.
Reply 1
Oct 16, 2023 | 11:16 AM
  #98
I just had my LTT installed with a New waterpump and I can see the difference immediately. I do also have the 3rd radiator installed, as it gets very hot here in Central Florida.
The car never passed 200 after doing a bunch of highway pulls and aggressive acceleration. I'm running LiquiMoly 5w-40 High Tech Lechtlauf
and just regular driving casually in and around town, it sat around 175 the whole time. I know the factory gauge isn't the most accurate but it's running much cooler than before.
Reply 0
Explore
Subscribe
