Preemptively replace water pump?
I have a 2005 C2S with 98k miles that I just purchased a month ago. I don’t have records as to whether the water pump has been replaced. I’ve currently got the serpentine belt off right now because I’m replacing the alternator and AOS. When I spin the water pump by hand it’s completely smooth and doesn’t have any leaks.
After I get the AOS buttoned up it’s going into the shop for a new IMS/Clutch/Rms. It’s an extra $1,400 to do the water pump and 160 degree thermostat at the same time.
So I have two questions:
1. Do these water pumps start to make noise before they fail (similar to how the idler pulleys will)?
2. Should I bite the bullet on the water pump and replace it now? Or wait for it or the engine to fail (whichever comes first) and just have it replaced?
2. I would. Better safe than sorry. I'd also replace the thermostat with a "low temp" (160degF) thermostat to reduce the chance/severity of bore scoring. And since much of the coolant is drained, assess the condition of the hoses and replace those also.
If you're doing the cooling system work yourself, get an UView AirLift to be able to pull most of the air out of the system when you start refilling it.
1. Sometimes. Sometimes they fail catastrophically and without warning, leaving you stranded. With the belt off, check the shaft radial movement. There should be very, very little movement. Also look for pink "crust" as a sign of (coolant) weeping.
Have you done the IMS Solution yet or are you considering?
(Assuming you don’t have a large IMS bearing engine already)
With 100k miles, yes I would replace the water pump. I would also replace the coolant reservoir as they tend to dry out and crack.
I don't understand the 160 degree thermostat thing unless you're racing. Seems to me you want the engine to warm up as quickly
as possible to prevent bore scoring, and change oil every 5k mi. I've been in Austin when the temp dropped to zero.
sierra73 (08-15-2023)
The following 2 users liked this post by jchapura:
Petza914 (08-14-2023),
TerrestrialFlyte (08-19-2023)
From my way of thinking, the warmer thermostat should get the block up closer to the hotter cylinder temp. sooner. I would also think Porsche would be using the cooler one if there was an advantage.
The following 3 users liked this post by spessx:
It's my understanding that because the low temp t-stat opens earlier, coolant is flowing earlier and then tending to more uniformly heat the areas that had no flow and cool the hot areas that had no flow, especially in the early stage of warmup. It seems coolant flow is especially important for this system and in regards to minimizing one or more of the root causes of bore scoring.
Replace Water Pump, Thermostat, Idler Pulleys and Belt.
No pink fluid leak on the garage floor or any kind of noise or warnings otherwise of the failure. It just seized up without warning, hence the serpentine coming apart as well. Total cost for all of it came to around $1,200 as I recall it but this was 6 or 7 years ago. And as jchapura pointed out, if it fails while your out on the road, you're stranded. One of relatively few failures I can think of....especially relatively inexpensive ones that will leave you stranded.
I have 72,000 miles on the original pump on my GTS and keep debating on whether to preemptively replace it out of pocket or wait for it to fail and have it covered by my extended Fidelity warranty like the one on the -09 C4S. Having to pull over roadside calling for a wrecker no matter where you are is not a great experience.
For a 997.1 car, I would replace the water pump and thermostat at 60K miles whether it fails or not. I do practice what i preach on my own 997. New waterpump at 60K and again at 120K.
lexhair (08-14-2023)
