Preemptively replace water pump?
Do y'all have any suggestions on what to do about the flywheel? TPWS said they look at the condition of the existing one and decide if it needs to be replaced. What's the reliability of dual mass flywheels on these cars? My car has 98k on it. It's $900 to replace it.
In my case, previous owner changed it together with clutch as seems that it was damaged. I read in other posts that it is usually replaced “every other clutch”; but I guess that depends, I’m not sure, but should at least be resurfaced if it is intended to be re-used (and sometimes this is a debatable field). A good Indy will tell you (and show it) why is needed (or not) but can find that is scored and need replacement. For the invoices that I got with the car, the dealer at that moment (Porsche Atlanta) put OE genuine Porsche parts but I heard that Sachs (OEM) is very good quality kit too. That was 25k miles (5yrs) ago. And yes, the flywell is expensive, specially if it is genuine OE. Just shop around it shoul go for OE between 1.4k and 1.9k. Very hard to find an OEM supplier for the flywheel so the price quoted seems that isn’t bad (if needed).
What's the consensus on this kit?
https://lnengineering.com/porsche-oe...riven-csp.html
Is the coolant additive worth it? This is the water pump to use right, not one with metal?
Edit: I did buy some sort of gasket glue to hold the gasket in place while fiddling with it during the install, so that wasn’t included.
@Petza914, just curious why one should avoid using a water pump with a metal impeller? It would seem to be a more robust solution, but I am far from educated on the nuances.
Thanks!
Bob
Thanks!
Bob
Thanks!
Bob
Thanks!
Bob
What usually causes water pump failure is wear in the shaft bearing to the point that the tension from the belt on the pulley causes enough impeller shaft deflection that the seal around the shaft starts to leak. For a water pump to pump efficiently, the cavity the impeller spins in has a tight tolerance to the impeller. With a metal impeller, as the shaft angle deflects from square, a metal impeller on the end of that shaft can start contacting the block cavity and milling the metal away, whereas a composite impeller has it's fins gradually worn away as the angle and contact increases as the bearing wears. Once the cavity in the block is deformed, even when a new pump is installed, because the cavity isn't perfectly shaped for the impeller anymore, the pumping efficiency will be reduced.
Thanks @Petza914 .
Bob
I've got a new mechanic who has cautioned me to stay away from a low temp thermostat and instead to use an OEM one. He said Porsche has an updated version. Is that ok? Should I be concerned? Everything else he's said has been spot on.
Your mechanic may not understand the reasons behind this. Only downside i can envision is if you live where it's really cold and the thermostat opening at 160 is going to prevent the engine from ever reaching proper operating temperature, but since.bore scoring is more prevalent in cold climate cars, odds are you'll end up with it anyway if staying with the OEM 180 thermostat.
....So in a nutshell, no, not OK.
