FOUND MY FIRST PORSCHE
#31
Saw the car today!!! Paint was awesome the interior and rubbers almost flawless. The car had not been detailed yet for sale as the coolant pump has a small leak and apparently a TSB as well , so they are waiting until everything is fixed . They allowed me to drive it around their plot. I drove it around until the temperature came up to just over 150 deg. then parked it. I did not go over 10 mph. I checked under the body panels, wheel wells, suspension parts visible from the sides thru wheels engine compartment etc. No signs of corrosion or rust on anything. I WAS SHOCKED. Wanted to negotiate to hold it with a deposit pending PPI by an expert but, they said per the GM the car was too old to take a deposit which made no sense. Through the salesperson the GM said it was going to take a month before it was ready for a test drive. Any thoughts???
#32
#33
Hootsama, I am a bit concerned too as I was searching for someone to do the PPI I found Porsche of Sarasota 30 miles away from them. This morning I called them and they have a coolant pump for $425.00 in stock. The salesperson did say there were 3 other interested parties so you may be right in that the seller wants to play us against each other once the vehicle is fixed.
Rod
Rod
#34
It might be a legit car with a legit story. But stories are stories... Good luck, and don't be deterred. Once you know what you're looking for just keep looking and going through the checklist. You will find the right car with the right stories but it's wise to avoid falling in love with any one car until all the boxes are checked. I know because I fell in love with the 911 that I ultimately bought and cut some corners on MY checklist...
Happy hunting!
Happy hunting!
#36
The fact they let you drive the car around with a faulty/leaking Water Pump sounds irresponsible.
These dealers let their salespeople drive the cars on the lot and also letting buyers drive it in it's condition, who knows whether car has been driven over temperature??
#37
Many times buying Porsche with patience is like defying gravity - However I would look for another 997.
TerrestrialFlyte (12-30-2022)
The following 3 users liked this post by TerrestrialFlyte:
#39
I'd guess they are waiting for the Title/paperwork and not sure of they will receive it or there is another interested dealer or they will deal the car out for another trade.
In the real world if a car needs water pump and you have buyer, you take deposit, get the car PPI/BSI and work the water pump into the sell price.
These Dealers smell funny.
#40
#41
HAPPY NEW YEAR TO ALL, I have worked on engines my entire life both gas and diesels. I am not familiar with Porsche motors but, have worked on Mercedes Diesels. If a coolant pump/ water pump is bad it will probably leak from the sweep hole. I saw no leaks on the ground from the vehicle when it was started in addition most Thermostats open in the 997 at about 160F so driving in the p/lot less than 10 mph until the temperature reached 150 F wouldn't do anything to the engine especially if the radiator was full. The mechanic who is in charge of the car had the key at his station and told the salesperson only for me to drive the car briefly around the plot.
Rod
Rod
#42
Sandwedge has experience with that dealership. Maybe PM him. That's a beautifully spec'd car! It will go fast. Lot's of money is coming into Sarasota for the season.
I'd grab it if you can!
#43
My parents condo had a water shower setup for cars. Basically a carport looking skeleton constructed of water pipes.
You pulled your car under it and turned on the water and car got good shower rinse. Of course only good for the exterior topsides to get the salt spray off.
The underside and brakes stayed crusty as hell.
My carport is probably close to 200' from the beach so I have quiet a few car that you'd think would block some of the dirt blowing in from the beach. Not happening. I'm sure it would be worse being parked closer to the beach but it's obvious it's just flying around all over the place no matter how close or away from the beach you are.
I know. There are far worse problems in the world and I'm not complaining. Just observing and providing feedback.
#44
I thought you were referring to the 997.2 MT at Suncoast in Sarasota. It looks like a great spec! Sorry!
I just moved from Longboat Key living directly on Sarasota Bay with a carport to Tarpon Springs. During the summers when I went north from Longboat for 5 months I kept my car in a product called the "Carcoon". It worked very well to keep all of that gunk off my 560SL yet circulating air. The 911 lives in NC so no need,
I now live in Tarpon Springs where I have a house with a garage so I don't need it. If anyone is interested in a used Carcoon PM me.
Rich
Rich
#45
I now live in Tarpon Springs where I have a house with a garage so I don't need tt. If anyone is interested in a used Carcoon PM me.
Rich
Rich
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
