Bore scoring
#47
We are using that car for our weekly BAT game
https://bringatrailer.com/listing/20...rrera-coupe-6/
If this one on the BAT auction had clear images of no scoring via scope imagery through the plug holes that looked good, would that bring an extra 10-15K?
#48
Received 1,895 Likes
#49
That’s the one.
#50
All these water cooled cars and the 993’s seem to have motor issues. Should have kept my 87 3.2 Carrera.
#51
Here's a quick partial list of Porsche Model failures:
356 - Engines run too hot. Rebuild usually necessary at 70K miles - Rust issues
1965-1973 911 - MFI issues - Rust issues
74-77 911 - Chain tensioner/Broken Headstuds/Engine runs too hot - Rebuilds common at lower mileage
78-83 911SC - Chain tensioner/Broken Headstuds, Bad syncros in Transmission - Engine & Transmission Rebuilds common at 70-80K miles
84-86 911Carrera - Valve Guide issues requiring top end rebuild
1989-1992 964 - Oil leaks due to no engine seals - Rebuild required - RUst issues at base of windshield front and rear.
1995-1998 993 - Air passages in heads get clogged requiring top end rebuild now costing $22K
1998-2004 996 - IMS issues as well as Cam Deviation issues which can require rebuild or engine replacement if engine grenades
2005-2012 997 - IMS issues on early 2005 models & Bore Scoring/cam deviation on all models which can require engine rebuild or replacement.
sparks259 (11-19-2022)
#52
This was pulled from BaT two hours ago. Significant metal flakes in the oil filter.
One-Owner 2009 Porsche 911 Carrera 4S Cabriolet 6-Speed https://bringatrailer.com/listing/20...-cabriolet-17/
#53
#54
Too bad good ones are going for $75k.
#55
#56
I'm a new member (but longterm reader of the forums) and didn't want to start a whole new thread about this so I'll just tag onto this thread.
I've wanted a 997 for a long time and I'm finally in a position to own one. I found a beautiful 997 a week or so ago and while the logistics of a meet-up were happening I did a deep dive into the whole bore scoring problem. I did know about IMS and felt like I'd accepted that risk. But I really didn't know much about bore scoring until this week. I drove the car yesterday but felt like the bore scoring issue was hanging over the experience.
I really want a 911 but I'm asking myself, is it worth a possible $30k engine rebuild? I can easily afford a 997 and all the maintenance, I could even afford an engine rebuild so that's not the problem. I have always lived very frugally an owned Japanese cars. This is supposed to be my fun 'go-crazy' purchase after years of being careful with money. BUT, this would be my one car, my DD. So I can't tolerate waiting 3+ months for an engine rebuild. Owning more than one car is also not an option.
I also think, when I look back will I regret not buying a 911 when I could have?
Anyways, so far I'm come up with a checklist to protect against bore scoring:
Am I missing anything here? I'm assuming a good PPI+bore-scope will be ~$400+$300? Every time I think I've found the solution to avoiding bore scoring I read some other post about someone discovering it without any of the usual warning signs.
Honestly I know this is a "small" problem percentage wise, but I can't believe 997 values with the threat of an engine rebuild hanging over these cars, but then 993 values, 964 values, etc.![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Has anyone on here owned/driven a GR86/BRZ? How comparable are they to the 997? I really don't care about a car being 'fast', I just want it to be quick enough to be fun (so not concerned that a 997 is faster). I'm more going for FUN but also somewhat practical.
- Bore-scope the engine from the oil pan
- Cut the oil filter open and look for metal flakes (assuming the oil has been in the car for at least 1000 mi)
- Check the exhaust tips for more soot on the left side
- Check the history for a warm weather car
- Look for frequent oil changes
- Maybe look for 3.6L vs 3.8L?
- Hope car was warmed up properly (at least 200 F for oil)
- Ask about oil consumption (high = bad)
#57
#58
It appears you are assuming all 997s are 997s. They are not. 2009 on, what is called a 997.2 with a 9A1 engine, has what appears to be a near bullet proof engine. If you are concerned, get a .2 car. I owned the previous engine and had two blow. So.... my next purchase would only be a 2009 or newer. YMMV
Peace
Bruce in Philly (now Atlanta)
#59
2009 C2S185K miles
Peace
Peace
To the OP, you can't really compare a 911 to anything else, because it's the only rear engine platform currently available which is part of what makes it so special.
#60
we used to think that was the case, but just in the last week we were made aware of 2 or 3 997.2s where scoring was just discovered, so looks like they're better, but not as "bulletproof" as we thought a year or so ago.
