Mr. 12 volt Carplay for PCM 3.0 (P2000 PCM30MD) install – short review, one problem.
@Thomas_ Just curious as I also just had my Mr12Volt installed on a PCM 3.0 in a 997 Turbo, was it also extremely tight when putting the PCM 3.0 back in place with the added harness in the back? I really needed to push it pretty hard to stay back in place probably squeezing the harness quite a bit...
I ended up reaching in from the back with my free hand and guiding the Mr 12 Volt wiring harness partially down into the center stack toward the AC controls, that created enough room for the PCM to re-install nicely.
@Thomas_ Did you ever install a backup camera? I installed the Mr. 12 Volt solution over the weekend and so far, I’m pretty happy. However, I’m unable to get it to work with my aftermarket Natika 720p camera. Just wondering if you (or anyone) has had success getting it to work with this reverse camera.
I have problems pressing buttons that are on the top and bottom edges of the screen. I have to use my finger nail which has a smaller surface area than my finger pad to press the small buttons
All sorted out, it's fixed now. Mr. 12 volt responded, and calibration is easy.
Here's how to calibrate the touch display. In the Mr. 12 volt main screen - touch the screen anywhere where there is no icons and hold for approx. 10 seconds and the touch calibration screen comes up. You just touch 5 crosshairs on the screen, and the calibration is done. This has to be done one time only and calibration is automaticly stored.
The Carplay works great - and now touch also, even in the corners, no problems at all. Very happy with this device.
I tried that method to calibrate my screen and it didn’t work. I stumbled upon this. From Mr 12 Volt menu —> Settings —> System —> Factory Mode —> Touch Calibration. That presented 5 crosshairs to touch and the touch response of the system has been so much better from an accuracy standpoint.
Now if I could just get my system to recognize via CANBUS when my PDK is put in reverse to show my backup camera, I’d be 100% satisfied.
Mr 12 Volt support has asked me to disable/uninstall my mods4cars smarttop module in hopes that will help. I plan to try that this weekend. Whenever I installed Mr 12 Volt (and previously the ISUDAR board), it disabled functionality to the smarttop mod. I had to go in and manually re-enable. So, there may be some sort of conflict.
I’ve tried this without success. No difference whether parking brake is engaged or not.
Please let us know, if you have any succes in getting the signal fom the CANBUS to register. Would be happy not to tap in to the 12v reverse light.
I don't have a PDK so I can't check it, but here's a post that says how to do it:
https://rennlist.com/forums/997-foru...l#post18777861
On my manual I had to tap into the reverse light trigger.
Thanks, all. I really appreciate the help and advice.
I did follow the instructions exactly as presented in this video.
I have PCM 3.0, PDK, and the Natika 720p camera. It appears Mr 12 Volt cannot distinguish when the car is put into reverse (via CANbus).
@Thomas_ Do you have a PDK or manual? Like you, I really don’t want to tap into any factory wiring for the reverse trigger.
