997-7s cab stiffening
4th Gear
Anybody had experience stiffening up a 997-1s cab. my car creaks with the top up when i go up or down our drive way at an angle. I don't hear it when the top is down. Any ideas? Is it a top latch adjustment or just the way it is? I've had coupes and targa's neither of which did it but......Thanks for the help John
I never noticed Flex with top up or down when I owned my 2006 Cabriolet 2 yrs ago. Perhaps your top is not securing tight enough?
Not sure of there are adjustments to tighten the clamping mechanism but assume that would help a great deal.
malibuvw (03-21-2022)
Treat the top seals with Gummi Pflege. Do the door and window seals, while you're at it. Apply using the bottle applicator, wait a few minutes, and then wipe away and buff the excess off.
My car is a coupe and it does this when sitting over night in cooler temps when I back up from the drive onto the street while turning sometimes.... Totally normal ...
FlatsixS (11-06-2023)
All cabs I have owned squeak and flex a little across the windshield. The Porsche is the one with the least amount I have ever seen, period, better than most 2 seaters - the worst was an MG-F. Try driving a Camaro convertible from 2021 - your Porsche will seem like a stiff board in comparison.
Porsche 911 Carrera Cabriolet (997) (2005 - 2008) (stuttcars.com)
Check out this press release on cab design-
When Guntherwerks were developing the 993 restomod, testing showed the cab has 66% less structural rigidity than the coupe. Not sure how improved it was made by 997 gen. All soft top Cabs are compromised to some degree
