Repairing my PDK Gearbox Experience & Guide
Old Aug 5, 2021 | 03:22 PM
  #61
jbolduc27's Avatar
jbolduc27
5th Gear
Just an update on having difficulties removing the PDK gearbox cover. My mechanic built another custom tool to pull the cover out and he was successful. He had to use a 1/2" thick steel plate to make sure it would not flex when screwing the bolts to pop the cover. It worked!
The defective PDK position sensor was replaced with a new position sensor from https://t-design9.com/ and that solved my PDK transmission problem! The car has been running smoothly for over a week now... what a relief.
I intend to go to a local track (Michelin Raceway Road Atlanta) with it in September and see how it handles more stressful conditions.
Old Aug 5, 2021 | 04:15 PM
  #62
9INE97's Avatar
9INE97
That is awesome. Be sure to let everyone know how it holds up.
Old Aug 5, 2021 | 05:05 PM
  #63
jbolduc27's Avatar
jbolduc27
5th Gear
I sure will!
T-design9.com says they used 2020 technology, did extensive temperature testing, etc. I am confident it will do well.
My mechanic put Motul 300 75w90 gear fluid in gearbox. He suggested I change it every year if I go to the track a few weekends a year, just to be on the safe side. Normally, you change that fluid every 12 years / 120,000 miles.
Old Aug 10, 2021 | 03:18 PM
  #64
yarindadon's Avatar
yarindadon
Default Hi
I have a 991 with a defective placement sensor, I ordered from t-design the sensor, and now the gear is removed from the car, I wanted to know how you built the special tool that holds the gear ⚙️ in place, maybe you have any schematics?
Old Aug 10, 2021 | 04:43 PM
  #65
Pinkawa's Avatar
Pinkawa
Hey please scroll up to #565, there is a drawing for the tool from Niklas Vemdal.
Good luck !
Old Aug 10, 2021 | 05:05 PM
  #66
yarindadon's Avatar
yarindadon
Good luck !
Thank you , do it’s the same for the 991?
cause I see it’s for cayman
Old Aug 10, 2021 | 05:23 PM
  #67
PV997's Avatar
PV997
Pretty sure the bolt holes are in the same place but that's just based on looking at photos. Bigger concern if it's an AWD PDK (c4, turbo) as the that plate design won't work with a protruding drive shaft.
Edit: Even on the 991 2WD the lower cap sticks out farther than on the Cayman so the tool may still need to be modified. You might search Ebay for photos of PDK transmissions out of the car so you can see the differences.
Old Aug 10, 2021 | 05:38 PM
  #68
PV997's Avatar
PV997
(deleted)
Old Aug 10, 2021 | 05:49 PM
  #69
yarindadon's Avatar
yarindadon
yes I have the c2s
Old Aug 15, 2021 | 11:03 AM
  #70
yarindadon's Avatar
yarindadon
Default Splitting the pdk
The special tool used to split the transmission, is only for splitting or it used to hold some parts inside to save their current position?
Old Aug 15, 2021 | 11:17 AM
  #71
yarindadon's Avatar
yarindadon
Default Hic
can you share some photos of the tool?
Old Aug 15, 2021 | 05:47 PM
  #72
amet's Avatar
amet
just to split the case open
Old Aug 15, 2021 | 08:44 PM
  #73
Kuro Neko's Avatar
Kuro Neko
Old Sep 21, 2021 | 08:34 PM
  #74
Spellbindehr's Avatar
Spellbindehr
4th Gear
Good afternoon. We're a shop in Burbank, CA and we're currently attempting the repair for the distance sensors on a 2012 911. New sensor from T9 is in, and in putting the case back together, I cannot push the bearings on the shafts enough to install the snap rings back in place for both shafts. This is a 2wd. I've removed the case a second time to see if something was binding, but nothing I can see. Was just wondering if anyone had faced the same issue, and how it was resolved.
Thank you in advance for any input.
-David
Old Sep 22, 2021 | 01:13 AM
  #75
Damien Law's Avatar
Damien Law
You need to carefully hammer the bearing down with a suitable tool
