Repairing my PDK Gearbox Experience & Guide
Old 11-29-2023, 12:08 AM
  #106
Wayne Smith
Wayne Smith's Avatar
Received 1,209 Likes on 776 Posts
Originally Posted by jerrysmalley
how does one get ahold of T Design?
Here is one of their links ...
https://t-design9.com/memory_module_porsche.html
Old 02-26-2024, 04:26 PM
  #107
Jameslee999
Jameslee999's Avatar
Default Help please after pdk distance sensor repair
Can anyone help...completed the pdk sensor replacement for T design following this guide and all was great or at least I thought so. I'm having an issue when cold...the box hesitates in 5th and 7th gear but only until warm then it's perfect . It delays the change in 5th and can rev out in 7th but literally minutes later it's perfect and will continue to be until allowed to be cold again.. any ideas? I carried out a recalibration and box full using an autel ? Any help is massively appreciated
Old 02-28-2024, 08:24 AM
  #108
t-design
Basic Sponsor
t-design's Avatar
Did you do the bleeding procedure after reassembly? It somewhat feels like hydraulics issue. Autel is fine.
T-Design9 : Mods and ergonomic accessories bespoke designed for Porsche cars
Memory Modules : remember SC **** settings; A/S/S, PSE, Spoiler, Sport/+ buttons
Phone Mounts : keep your phone up and close and charged
Cupdholders, Sunglass Holsters and more at T-Design9.com
Old 03-25-2024, 03:47 PM
  #109
bxster_2012
bxster_2012's Avatar
Default PDK calibration fails after Shift Rod position Sensor replacement
Hi, I have just had the T-design part installed in my 2013 Boxster 981 PDK as well.
While the installation through my trusted garage worked fine (and they checked if all the soldered wires as OK), while running the calibration (as per their info) it seems to get stuck during the procedure.
I have asked them already if they can touch base with T-design, but believe they didn’t. They are getting a bit lost of ideas, as far as I have understood from them. The question is if anyone (or best T-design) has any ideas on what to do in this case. per my understanding they have done the short and the long calibration procedure, but not necessarily the Bleeding, Can someone explain to me what the „bleeding procedure“ is supposed to be and/or has an idea to get this working. I - presently - doubt that its either a faulty PDK sensor from T-design, nor that it is a problem with the installation.
Any help is LARGELY appreciated
thanks in advance and by the way: great community here!!!
best,
andreas
(p.s. unfortunately I don’t have the error code (yet)
Old 04-23-2024, 08:52 PM
  #110
Lostpilot28
Lostpilot28's Avatar
Hi everyone,
I'm the next lucky recipient of the "Possible R gear fault Driving permitted" message. I'm in a base Cayman 718 (2017 model year). The battery is fully charged and the car has been driving well for 77,000 miles. Woke up yesterday morning and got the error message along with "Engine control fault Consult a workshop Driving Permitted". The car won't move forward or backward, and if it's in gear the "2" just blinks erratically.
I used my bluetooth OBDII adapter with the Torque app and got a P1733, but when I use the iCarSoft unit I don't get any faults. I have disconnected the negative terminal on the battery a couple times to "reset" the ECU/TCU, but the problem persists.
Are there any other troubleshooting steps I can take to confirm what the issue is?
Old 04-23-2024, 11:58 PM
  #111
stjoh
stjoh's Avatar
Originally Posted by Lostpilot28
Hi everyone,
I'm always suspicious about the aftermarket code readers, I suggest you try to find somebody with a PIWIS to capture the code and sub-info. Where are you located?
Old 04-24-2024, 10:51 AM
  #112
t-design
Basic Sponsor
t-design's Avatar
1733 is a distance sensor error, there is no ambiguity in this case really
"1733 Displ. Sensor shift rod gears fault impulse signals 1/3 - Channel 3"
Hi everyone,
Old 04-24-2024, 11:17 AM
  #113
Lostpilot28
Thanks, guys...that's what I'm trying to confirm is if the OBDII code may not be telling the whole truth. I'm located in Boise, Idaho...I have a repair shop locally and a dealer. The cost of them spending a few hours with a PIWIS + my towing expenses is going to be about the same as me buying a knockoff PIWIS (I think).
Question, though...is the blinking gear "2" indicative of anything?
2nd question - is the Possible R gear fault Driving permitted message on the dash in line with the P1733 code?
Old 06-05-2024, 02:07 PM
  #114
cbracerx
cbracerx's Avatar
PDK Rear Case Sealing Caps - Updated Part?
I’ve got a 987.2 PDK getting a new distance sensor. I had the Porsche dealer order replacement caps for the rear case, which are superceded from the original part number. Ordered 9G1.321.360.00 and got 9P1-301-125. This is what the new caps look like. Any concerns?
EDIT: Seems like part 9P130615 is the part needed for the 987.2 cover seal. It looks like the part I removed:
Removed Caps
Old 06-05-2024, 03:33 PM
  #115
Lostpilot28
Yeah, that's what the replacements look like for me as well. I put them in as is and haven't had a problem so far.
Old 07-08-2024, 01:18 PM
  #116
Ubermensch
Ubermensch's Avatar
This post was started a few years ago, so I thought I check in and see how people's sensors and repairs are holding up. I'm getting a 1733 error with increasing frequency and likely need to deal with it soon.
-Shawn
Old 07-08-2024, 09:35 PM
  #117
cbracerx
cbracerx's Avatar
My most recent distance sensor replacement repair is holding up fine so far. Calibrated on the first try. Cayman drives like new. Client is very happy!
Old 07-09-2024, 08:02 PM
  #118
Kuro Neko
Kuro Neko's Avatar
Received 1,747 Likes on 661 Posts
-Shawn
This died in June 2021, at 52,000 km.
It was replaced with a T-Design module, and in July 2024, at 79,000 km has performed faultlessly... not a single reset, error, or concern.
t-design (07-10-2024)
Old 07-10-2024, 11:00 AM
  #119
t-design
Basic Sponsor
t-design's Avatar
Originally Posted by Kuro Neko
What a great paperweight!
Old 07-11-2024, 09:08 AM
  #120
Ubermensch
Ubermensch's Avatar
Thanks for the follow up responses! Looking for a local installer now.
Quick Reply: Repairing my PDK Gearbox Experience & Guide
