Another oil analysis
Old 03-28-2020, 11:19 PM
Petza914
Petza914's Avatar
Received 6,454 Likes on 4,115 Posts
Looking at the added reports, copper and lead is bearing wear. That's not good and you guys will need to shorten your oil change intervals. I don't like to see any wear metals in double digits in modern engines. In an 80s 928 it's or a 70s Camaro it's a little more normal, but not in these motors.
Old 03-28-2020, 11:39 PM
andy93si
andy93si's Avatar
Here is a report from a 2006 997.1 S
Old 03-29-2020, 12:12 PM
C4SDayton
C4SDayton's Avatar
Originally Posted by Wayne Smith
I'd love to hear comments. Flame away!!!
Mobil 1 shears down quickly to a pretty stable level as I understand. There is plenty of additive left as the sample says. Your car has gotten beyond 134000 miles well enough. I'd go to 6-7k miles next time and see. I used MSO2 my last change and added about 1.4 containers of MSO2 plus 8 qts M1 to get me to 1 bar below top of measurement range on my 997.1.
Old 03-29-2020, 12:22 PM
TheBruce
TheBruce's Avatar
@Wayne Smith wait...what GTS are they talking about? Were you getting a PPI on a new ride???
Old 03-29-2020, 01:20 PM
david
david's Avatar
Methinks that Wayne may be looking at this!?
https://bringatrailer.com/listing/20...ign=2020-03-28
PS I'll submit my last (& 1st) report when I come up for air...great work Karl!!!
Old 03-29-2020, 02:26 PM
Wayne Smith
Wayne Smith's Avatar
Received 1,195 Likes on 762 Posts
The GTS was a friend's car. 80K and a pristine oil analysis and a very clean filter.
As much as I think I would live a GT3 (or better yet a TTS) that's not happening in the near future!!!
Old 03-29-2020, 03:23 PM
Fahrer
Fahrer's Avatar
Originally Posted by wjk_glynn
Updated March 28th, 2020...
Karl.
This is nice summary. What it tells me is that all of these oils perform basically the same. And if another set of samples and results are developed, the numbers will be somewhat different but still will tell us that basically they perform the same.
Old 03-29-2020, 03:42 PM
ltcjmramos
ltcjmramos's Avatar
I be the friend. Analysis attached (removed now.) To be reposted.
Last edited by ltcjmramos; 04-01-2020 at 12:47 AM. Reason: Added oil analysis .pdf
Old 03-29-2020, 04:02 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,536 Likes on 925 Posts
AhaAhahhHHAHAH!@!!!!!!
My aluminum and iron, together, are above everyone else's .2 numbers AHAHAHA!!!! 5 + 8 = 13. 13!!! 13 !!! I AM DOOOOOMED!!!!!
Peace
Bruce in Philly
wjk_glynn
wjk_glynn's Avatar
Originally Posted by ltcjmramos
I be the friend. Analysis attached.
Hi Joe,
The report doesn't mention it. What was the Oil type/grade, and any additives ?
Thanks.
Karl.
Old 03-29-2020, 04:33 PM
ltcjmramos
ltcjmramos's Avatar
Mobil 1, 0-40, no additives.
Old 03-29-2020, 04:55 PM
wjk_glynn
wjk_glynn's Avatar
Updated Post #4 with the latest reports to date...
Karl.
Old 03-29-2020, 05:24 PM
Rampage
Rampage's Avatar
OK adding mine to the database, a 2006 997.1 S
Keep in mind all the distances are in KM - not Miles like the paperwork says! The first sample was taken on my first oil change after buying the car. I suspect it was Mobil as the paperwork I got with the car indicated it was dealer serviced recently. But I'm not 100% sure it is 'unknown' for all intents. I put in Mobil 1 0W40 at that change, and that is what this report is for.
I'll get another Mobil 1 0W40 sample when the car comes out of winter storage in a few weeks
Old 03-29-2020, 05:49 PM
Joel987
Joel987's Avatar
Are these numbers in post #22 telling us the numbers are good, bad, indifferent? Could one conclude that Mobil 1 is not bad after all? And would one derive that cwheeler's engine has wear problems?
I've been reading lots of posts on oil analysis. Other than getting a baseline and following your own engine with subsequent analyses, I am having trouble comparing different cars with different oil to draw any conclusions. I am not an engineer and don't even play one on TV!
Old 03-29-2020, 05:57 PM
cwheeler
cwheeler's Avatar
Quick Reply: Another oil analysis
