OEM SSK - very happy!
Old Aug 31, 2019 | 07:11 AM
FamilyMan928's Avatar
FamilyMan928
Default OEM SSK - very happy!
Yesterday I had the OEM Short Shift Kit installed, and WOW, I'm super pleased with it.
It's much tighter, shorter throws, and no play in it at all. The stock shifter had some wiggle and was just a little too sloppy.
I know there are other more popular options, but I was looking for an improvement over stock and didn't want to spend too much $$$.
I purchased it from suncoast: https://www.suncoastparts.com/product/99742498300.html
And had it installed by a local Indy shop.
The only complaint is that I noticed getting into first is a little hard at times, but hopefully that will sort itself it out after a few more miles/smiles!!
The best advice I got from the Forums was this: "Go with the OEM SSK and you'll be happy, but just don't drive a 997 with Numeric!"
Old Aug 31, 2019 | 07:02 PM
jhbrennan's Avatar
jhbrennan
My experience with the SSK is similar...but going into first actually gets worse as the weather gets colder. I found that if I pull the shifter towards 2nd gear (not into 2nd) then move shifter into 1st it operates much smoother.
Old Aug 31, 2019 | 07:29 PM
csmab's Avatar
csmab
Definitely agree with your comments. Mine behaves the same way.
Regards
Old Aug 31, 2019 | 08:03 PM
FamilyMan928
Thanks, I’ll give that a try. Do you know if this is due to something inherent in the design?
Old Aug 31, 2019 | 09:06 PM
jamesinger's Avatar
jamesinger
I have issues with the SSK and getting into first when cold as well. Sometimes, I even just get frustrated and start out in second. Once the car is at temp, it is no longer an issue. I also noticed that when I drive to work, or wherever, it might feel notchy or tight but driving back it is a lot nicer. I wonder if that is just psychological though. When the car is warm, the car shifts better than any car I have had, even Hondas with their super slick MT. When it is cold, the whole first gear thing makes it the worst until I get to temp IMO.
Old Aug 31, 2019 | 10:09 PM
FamilyMan928
Sounds like I'll have to drive around my neighborhood before leaving for work!
Old Aug 31, 2019 | 10:25 PM
jamesinger's Avatar
jamesinger
^^^ yeah, I actually have 2 options to get to the freeway, and if it isn't my morning stop and go commute, I will take the longer way. If it is morning, whatever, in LA, you just stop/go/stop/go...with sudden bursts of people stupidly flooring it to the next choke point. In any case, mine is factory installed. I drove other 997 versions before buying my car. The shifter (once warm) was a high point of my test drive from a (VERY) cold start (i.e. sitting in a garage for quite a while on a tender).
Old Sep 1, 2019 | 10:30 AM
Petza914's Avatar
Petza914
I have the OEM SSK in both my 997s and don't have the 1st gear issue you guys are mentioning. If you haven't renewed your dear oil with Mobilube PTX, do that immediately. Don't use any other fluid and it may dramatically improve the cold shift into 1st as well as the warm shifting.
Old Sep 1, 2019 | 11:43 AM
kellen's Avatar
kellen
Had the OEM SSK and liked it a lot. Added the function first shift right solution and it made it even better. Current car went straight to the numeric shifter.
Old Sep 1, 2019 | 06:16 PM
FamilyMan928
Yeah I was just reading in another thread that someone had success with this approach (plus new engine mounts).
I’ll give Mobilube PTX a try, thanks!
Old Sep 1, 2019 | 09:44 PM
Prairiedawg's Avatar
Prairiedawg
Just curious what the issue with the Numeric ? It looks like a high quality piece, albeit a bit pricey.
Old Sep 1, 2019 | 11:15 PM
FamilyMan928
Numeric is much better and I’d regret not spending the extra money to get one!
Old Sep 1, 2019 | 11:18 PM
Prairiedawg
Oh, ok I get it. I misread your quote. Sometimes I am a bit dense
Old Sep 1, 2019 | 11:45 PM
FamilyMan928
Haha, no worries... I can see how you could have taken it the other way. 😁
Old Sep 7, 2019 | 08:00 AM
FamilyMan928
Quick update: I had the trans oil changed (Mobilube PTX). Also had them ensure the cables were retained properly. BUT, still hard to shift into 1st.
I've read quite a bit on the forum here and it sounds like my next steps are new engine mounts and then maybe changing the plastic bushings to metal.
In the meantime, I'll follow the procedures others have noted (move gear towards 2nd, then move up to 1st).
