OEM SSK - very happy!
Quick update: I had the trans oil changed (Mobilube PTX). Also had them ensure the cables were retained properly. BUT, still hard to shift into 1st.
I've read quite a bit on the forum here and it sounds like my next steps are new engine mounts and then maybe changing the plastic bushings to metal.
In the meantime, I'll follow the procedures others have noted (move gear towards 2nd, then move up to 1st).
Did you have problems shifting to first before the change to the SSK? I don’t have the SSK, but did have the intermittent issue of not being able to get it into first sometimes, and after having my dealer bleed the clutch, the problem went away.
2009 C2S 140K miles
A few things.....
1 - 1st gear issue... common, and many get relief as Mr Petza noted from replacing transmission oil with what is spec'd in my (and your?) 2009 manual, Mobilube PTX. Read more here: https://rennlist.com/forums/997-foru...-gear-oil.html
2 - A shorter shifter lessens your leverage.. it makes your arm action less powerful so any resistance that is already in the system will get stronger. An almost non-existent 1st gear issue will become noticeable and may crest your WTF threshold.
3 - Short shifters are not for everyone. I for one, don't like them. It is a matter of taste.
I installed the Numeric shifter which has three leverage position you can select. Make it short or long. You can make it stock if you want. I set mine as stock. I have driven other's Porsche with short shifter kits and I just don't like the extra effort to shift... I find it annoying. But that is just me... YMMV. Read here... tons on the Numeric: https://rennlist.com/forums/997-foru...l#post11734128
Peace
Bruce in Philly
A few things.....
Peace
Bruce in Philly
Yes, I did have some intermittent issues prior to installing the SSK. After the install, it become more pronounced and almost at every shift into 1st. As Bruce said, the SSK amplifies the resistance.
2009 C2S 140K miles
A few things.....
Peace
Bruce in Philly
A few things.....
Peace
Bruce in Philly
Wow, if happening at every shift into first, that would really annoy me. Cars behind me would be honking all the time. In the interim I guess you can shift into first as you’re coming to stop so that you know it can be in first as you start again or shift into second before going to first but that doesn’t always work either. Let us know what finally works for you as the fix.
It's weird though, yesterday I drove around for 50 miles and there were times when it fell into 1st pretty easily, but more often than not I felt the resistance going into 1st. I've been doing the stick move to 2nd, then shifting into 1st and that is the temporary work around.
I'll keep exploring the options to see how to minimize (or eliminate the issue). We've got about 2 months of good driving weather here in Chicago before I have to start thinking about winter storage. So, we'll see how it goes!
Fortunately, there's great people on this forum with experiences that I can learn from!!
Yup, it's been pretty annoying. I might have to change the title of this thread!
Another trick that may work is when you're sitting there in neutral with the clutch out, blip the gas before depressing the clutch and then push in the clutch and move the lever to first. Blipoin the gas with the clutch engaged (pedal out, not in) will spin the internals of the transmission so they're moving as you try to engage the gear which should help it slip in easier.
FamilyMan928 (09-09-2019)
