LAPower bluetooth?
Old Apr 2, 2021 | 04:46 PM
  #646
RennKit-Dave's Avatar
RennKit-Dave
Former Vendor
Did you disconnect the BTR-3 module and see if the fuse remained intact? On my '07 Turbo, the fuse was blown and I didn't know it. I kept wondering why the BTR-3 module had no power when I hooked it up. Simple check with volt meter showed no volts at the lighter. Replaced fuse, all was well.
Old Jun 29, 2021 | 07:23 PM
  #647
Climarepair.com's Avatar
Climarepair.com
Former Sponsor
Originally Posted by qwertyqwerty
I did it off of the 12volt outlet (cigaret lighter style) by the passengers feet.
Yo can also buy some special filters to avoid that noise.
Old Jul 28, 2021 | 07:24 PM
  #648
The_Ruski_Driver's Avatar
The_Ruski_Driver
6th Gear
I got this installed today and I can hear audio just fine. However, I cannot make or take calls through the device. I restarted my phone a few times and tried re-pairing the device. Does anyone else have this issue?
Old Jul 28, 2021 | 07:40 PM
  #649
mwoc's Avatar
mwoc
Just to confirm did you use the microphone that came with the adapter? I ended up ordering the mic from Enfig which fits under the top cover of the steering column.
Old Jul 28, 2021 | 07:50 PM
  #650
The_Ruski_Driver
6th Gear
Yeah I did. Usually when you're on a call with a Bluetooth headset you can choose between iPhone, speaker, or <your bt device>. When I make calls, it's just showing the standard iPhone and speaker options.
Old Jul 28, 2021 | 08:33 PM
  #651
mwoc's Avatar
mwoc
That's strange - in your bluetooth settings do you show it connected to Car Kit?
Old Jul 29, 2021 | 01:06 PM
  #652
The_Ruski_Driver
6th Gear
Fixed it. The 4 switches on the back were in the wrong place.
I LOVE this thing!!!!
Old Jul 29, 2021 | 06:48 PM
  #653
qwertyqwerty's Avatar
qwertyqwerty
Can I remove the navigation CD unit now that I have the LA Power bluetooth adapter in? it has been the difference between fitting things int eh trunk and not more than once?
Old Jul 30, 2021 | 04:53 PM
  #654
mootsvamootsrsl's Avatar
mootsvamootsrsl
Thanks for sharing this. This is great
Old Aug 5, 2021 | 01:21 PM
  #655
997_flo's Avatar
997_flo
Just to add that if you purchase the newer Mr12V that comes with the 3 headed harness then you do not need to follow the instructions in the beginning of the thread where the wires needed to be rearranged. It is simply plug and play.
I have the CD changer w/ Bose.
Old Aug 30, 2021 | 12:44 PM
  #656
pepperpepper's Avatar
pepperpepper
Question for y'all, when installing the Mr12V and tapping into the power for the PCM how exactly are you managing that? I don't want to do anything to the stock radio power harness that could cause me problems later on... I could use the 12v for the plug in in the passenger footwell, but as far as I understand that's an un-switched connection and I worry about battery drain in the winter.
Old Sep 22, 2021 | 06:08 AM
  #657
GarethWyn79's Avatar
GarethWyn79
Originally Posted by TEF
Thanks for your prompt assistance.
To clarify a few things, my Boxster S is equipped with a CDR23 radio with a rudimentary display, so there is not much to photograph. However, after pressing the CD button, the display reads "No CD". Nevertheless, the CDR23, per the manufacturer's website, is compatible with a Mr12v. As for the optical cable, the newer Mr12v's arrive with an idiot proof harness. No more does one have to disconnect on leg of the optical pair and connect it to the corresponding leg of the Mr12v. The new system comes with three plugs (one female and two males) that connect as follows: one unplugs the male optical plug on the back of the PCM unit and this goes into the female plug of the supplied harness. Then one of the male plugs on the supplied harness goes into the back of the PCM and the other male plug (on the longer leg of the harness) goes into the Mr12v. Since this is all prepared by the manufacturer, I am thinking there is not much chance of goofing up this circuit.
The power circuit seems simple enough: the red (positive) connects to the red/green wire while the black (negative) goes to the brown wire. The Mr12v's blue power light is on and the entire radio/amp combo does not function when the power plug is removed from the Mr12v. Therefore, I don't see a problem is this area..
Following your suggestions, I tried outputting music from my phone via blue tooth into the Mr12v without success. Secondly, I tried turning the radio off and on and still not luck. I did not have a chance to try the analog connection, but neither this or the USB connection worked yesterday. While I loath to say this, perhaps my only option is to have a Porsche dealer activate my CDR23, so it recognizes a CD deck (or in my case, the Mr12v). Aside from the cost, it is a 160 mile round trip for this process. The manufacturer's website does say that some cars without a CD deck may require this procedure. In your case, you seemed to have lucked out.
Should you or anyone else have any suggestions, it would be appreciated.
Hi TEF
Did you ever resolve this issue? It sounds exactly like my experience!
Gareth
Old Sep 22, 2021 | 08:28 AM
  #658
TEF's Avatar
TEF
Given the distance and cost, I never visited a dealer plus I traded the 987 BS for a 981 BS, so the issue is, for me, moot. If your 987 has no cd deck and is behaving like mine, I suspect two causes: reprogramming is necessary or a defective Mr12v. Good luck.
Old Sep 22, 2021 | 01:40 PM
  #659
qikqbn's Avatar
qikqbn
If you no longer want to use the outdated navigation that comes with your PCM... go for it.. You will have an error message "navigation missing" ,or something like that, pop up on your pcm when you start the car and will have to get it coded out. A local dealer with a durametric or fellow rennlister with Foxwell can switch that off.
Old Sep 22, 2021 | 01:47 PM
  #660
qikqbn's Avatar
qikqbn
Actually I have my power tapped into the same power wire as the PCM unit.. It's a bit more time to get to by removing the pcm unit, but not too bad. It's the thicker red/green wire. You will also see a thicker brown wire for ground next to it, but stick to the advice of grounding it to the chassis.
I followed the tip here:
https://rennlist.com/forums/997-foru...l#post15960225
I attached the ground wire to the metal brace supporting the center console as mentioned in the thread and no more whining sound.
