LAPower bluetooth?
#391
Hi everyone
Glad to find this thread as I'm looking for bluetooth hands free & music streaming solution.
my 2003 Boxster came with CDR-23, BOSE system but NO CD Changer..
I'd appreciate the input about the install in my specific setup as most of the installs shared in the thread were for newer 9x7 PCMs..
Thank you..
Thank you..
#392
Been reading this thread - immensely useful!
I have a 997.1 with CDC, Nav and Phone. Putting the unit in the current phone location seems a neat approach. I like the idea of using a fuse tap - which fuse would I use? Never put one in before, but feels better than splicing the existing power leads... Is it easy to run wire back to the unit from the fuse box?
#393
#394
FYI I had my unit for a while but finally installed. Great instructions. That should be a pinned link, perhaps in/from the first post, along with the updates w/ the new MOST harness as instructions still have the old harness. The only problem was that I had no MOST, I unplugged and replugged all the connectors and it started working.
I did have noticeable alternator whine upon initial install. I did two things, one (or both) of which fully solved the whine - no hint now, even w/ radio cranked on null input.
1) Moved the LAPower ground wire from the 12v cig lighter brown negative wire, to a separate ground. I used a screw holding a trim piece, see pic.
2) Twisted the LApower red and black (neg and power) leads together along their length.
#395
Hi all,
Very insightful thread about the LA Power adapter. I have ordered one and will be installing it in the coming weeks. Plan is to put it behind the PCM and draw power from the cigarette lighter, however I was wondering whether that might cause me any problems if I'm putting the car on a Ctek charger at some point? I usually have something connected to keep the car's battery healthy during the winter months which is charging the car via the cigarette lighter, just curious if anything can happen to the adapter if is connected to the cigarette lighter and an electric charge is coming in the "wrong direction", i.e. going into the cig lighter?
If anyone else is using a Ctek or other charger and has the adapter installed drawing power from the cig lighter, it would be great to hear from you.
Best wishes
Best wishes
#396
there are a few blank unused power outlets in the fusebox that is switched on/off only when the car is on (not constantly switched on such as the cig lighter) - i would highly recommend using one of those instead. I have used one of those as I have installed a switched phone charging port that only is powered on when the car is on - search previous threads here re installing car cameras and similar accessories, the fuses to use will be there (as well as ideal spots to ground as well).
if you tap into the cig lighter to power the LA power you will cause a parasitic drain on your battery - even when the car is off with the alarm set ON. Another suggestion is go over the tranzitBluHF install thread - the exact wire to tap into the PCM harness (thats switched on only when the car is unlocked) is another suggestion to tap into the power.
EDIT - C1 & C5 are the fuses for for a switched power (only on when your car is on full accessory mode) - use either of these.
Hi all,
Best wishes
Best wishes
#398
The thread was provided to me by an Ebay seller of this adapter as he could not provide a PDF of the product's installation manual. While I have read the thread from beginning to end, some of the entries in the abstract are rather confusing. Most above are pleased with the product and think it's even better than the Denison unit costing three times more. The other thing noted in most of the postings is that many of you have more sophisticated hardware consisting of Bose Nav/Phone units with some sort of display. Mine is the rather pathetic CDR 24 radio w/o CD deck in a 987.1 2008 Boxster S. In reading about the Denison, it seems that (with my CDR 24) it offers only inputs for the ipod and analog devices, but NO BT or phone utilities. The vendor tells me that this product is compatible with my CDR 24, but little else. If purchased, would I have the same limitations as the Denison unit? Has anyone here done an installation on a Porsche with the CDR24 and, if so, what were the results?
Thanks in advance for any advice on the matter.
#399
As long as you have the MOST fiber ring, it should work.
Good luck!
#400
#401
Thanks for the tip about the whine, I switched the ground and now it’s quiet.
The following 2 users liked this post by Moedavis:
8KaboveMSL (12-29-2020),
jayi836 (07-10-2019)
#402
hey guys just to confirm - if i have the 6 disc cd changer i do lose the functionality of it correct?
also most of you guys bought from eBay seller correct?
im goign to remove my pcm to get it painted, i figure while everything is apart i will remove the tranzit bluHF and install the laPower instead.
thanks guys
thanks guys
#403
Your call, but I would simply replace the CD changer with LA power unit in the frunk. This is what I did and it continues to work perfect. No need to do anything on the inside.
jayi836 (07-09-2019)
#404
Can someone point me to the correct wire to tap into the pcm power source? Currently I'm tapped into the power port on the passenger side and am worried about drain on the battery.
I have a 2006 PCM 2.1 with Nav and no CD.
