996 Turbo Forum 1999-2005
Ultimate Motorwerks Rear Wing Lift Cylinder Repair Kit
Old 09-06-2017, 06:18 PM
  #91
z06801
z06801's Avatar
Hey Kevin are these ready to go? I'm going to need both items I think, it's off the car so I should pull it apart and take a look.
Old 12-16-2017, 05:21 AM
  #92
TT Oversteer
TT Oversteer's Avatar
I just pulled my system apart and found the rams to be ok but the plastic lift block inside the pump has cracked and failed. Hoping to hear if this part becomes available soon.
Old 12-16-2017, 09:11 AM
  #93
jpflip
jpflip's Avatar
May be you can ask "grenncalex" to fabricate one? https://rennlist.com/forums/996-turb...wing-pump.html
Old 01-30-2018, 03:16 PM
  #94
mffarrell
mffarrell's Avatar
Has anybody tried Kevin's ram repair yet?
Old 02-02-2018, 07:47 PM
  #95
gtred
gtred's Avatar
I just ran into this when I did a search for 996 turbo wing repair:
I'm in.
The following 2 users liked this post by gtred:
Dingo (03-15-2021), m54samrr (03-23-2020)
Old 02-02-2018, 08:14 PM
  #96
Kevin
Kevin's Avatar
The engineering feature that I offer with my design is reinforced CNC'd brass features to reduce the stress on the replacement orings. If one does have a future failure you can take the cylinder cartridges apart and repair for $0.40
The cost of repair is $248.00 per cylinder...
Old 05-16-2018, 07:07 PM
  #97
993GT
993GT's Avatar
PM sent,
Thanks,
Rob
Old 05-22-2018, 09:29 PM
  #98
champignon
champignon's Avatar
Originally Posted by gtred
I just ran into this when I did a search for 996 turbo wing repair: https://www.youtube.com/watch?v=mRHUeuESl-U
I'm in.
Got my turbo wing rising
Old 05-23-2018, 10:12 AM
  #99
Evolution
Evolution's Avatar
Just picked up my rebuilt system at the post office on my way into the office. Install tonight. Looking forward to a functioning unit (on the car). Will report back post-install and testing. Thanks Kevin!
-Joe
Old 07-04-2018, 08:57 PM
  #100
2fcknfst
2fcknfst's Avatar
Received 4,123 Likes on 3,120 Posts
Originally Posted by Carlo_Carrera
This is real life.
Let me guess, you a millennial?
Lawyer is my guess.
Old 07-13-2018, 03:32 PM
  #101
BillZ260
BillZ260's Avatar
Kevin is awesome to work with, his solution works! I had him bench bleed and test the system for the extra $100, it came from him all boxed up clean and ready to install. No muss, no fuss. Has been working for a few weeks now
Old 09-25-2018, 04:19 PM
  #102
smsarchitects
smsarchitects's Avatar
subscribed, where are they available?
Old 09-26-2018, 03:54 AM
  #103
Kevin
Kevin's Avatar
I can rebuild your failed lift cylinders. $248.00 each..
You can email me kevin@ultimatemotorwerks.com
Old 01-07-2019, 02:02 AM
  #104
vrage
vrage's Avatar
Kevin to the rescue for failed Spoiler.
Very much interested, but how to locate if it is the failed hydraulic cylinders or the hydraulic pump, the spoiler works for now but gives an error message in the dash.
Please suggest Kevin
3stewarts (03-14-2021)
Old 01-07-2019, 02:16 AM
  #105
Kevin
Kevin's Avatar
You will need to refill the hydraulic system with Pentosin and bleed. In this thread https://rennlist.com/forums/997-turb...epair-kit.html
Go to post # 10 for simple procedure.
Quick Reply: Ultimate Motorwerks Rear Wing Lift Cylinder Repair Kit
