996 Turbo Forum 1999-2005
New High Speed Data Logger Debut
Old May 9, 2011 | 09:28 AM
  #46
pete95zhn's Avatar
pete95zhn
Former Vendor
Kevin, which inputs are there ( pins in Motronic ) to be used to log EGT? I guess you need to use amplifiers between EGT sensors and Motronic?
Old May 9, 2011 | 02:37 PM
  #47
Kevin's Avatar
Kevin
Jon, the "load" values have a purpose for the future modules. The readings from the ECU are solid and will give myself and customers a solid baseline for torque models.
Brenton, congrats on the new purchase. The data from this new tool requires some basic engine knowledge. For example: A question that repeats itself over and over is > where is my boost. The answer isn't straight forward. A boost leak will show itself real quick when one looks at the "requested boost" and compares it to the "actual boost" If you ECU is requesting 1 bar and you see .6 bar. We have a leak.. However, if the requested boost is alot lower than what you should normally see, you should look to the other engine sensors and check for any stored engine codes. You might find out that you have a fuel pump failing > timing and boost will be pulled.
As far as in car viewing, a video output is planned for "later" development and release. For safety I do not recommend laptop viewing. What I have told customers over the years is to start the datalogging feature and stowe the laptop on the passenger side floorboard. Out of sight/out of mind. If you have a passenger he can view the Real Time values that a displayed.
There will be instructions for all sensor values that we are logging. I have spent hours in the past explaining all the raw data to "many" folks here on this board.
Pete, for the 996TT ME7 the EGT values are calculated internally in the code. For the 997TT the values are picked up from sensors mounted in the turbine housings.
Old May 24, 2011 | 03:55 AM
  #48
Kevin's Avatar
Kevin
Today has been a milestone for the new data logging tool. The tool was used to check and clear engine DTC codes prior to starting the logging function.
Here is the new screenshot for Live Data
[IMG][/IMG]
Old May 24, 2011 | 06:45 AM
  #49
akfalar's Avatar
akfalar
Default Just used the Logger tonight...
Thanks Kevin. As always the support goes way beyond the threshold of value.
Here is the not so good news.
File Type: jpg
Old May 28, 2011 | 07:43 AM
  #50
drvik's Avatar
drvik
Hi Kevin,
Just joining this thread late... is this also designed to work on the 997.1TT??? How long before it is commercially available?? If it is still in beta, would you like a beta tester based in australia?
Cheers,
drvik
Old May 28, 2011 | 01:32 PM
  #51
Kevin's Avatar
Kevin
drvik, welcome to Rennlist. The datalogger is up and running and ready for sale. It will work on the 996TT, 996GT3, 997.1TT and 997GT3.
Please email me.. Thanks..
Old May 29, 2011 | 05:31 PM
  #52
Cueto's Avatar
Cueto
FYI guys, I got the dataloger running under Bootcamp-Windows7 64 bit on a macbook pro. Worked real nice and had no issues with it.
Now I need to fix some boost leak issues with my car...
Old Jun 4, 2011 | 02:43 PM
  #53
Kevin's Avatar
Kevin
Yes, the Macbook logs look pretty good. I was hoping to see 100 lines per second with the MAC.. I counted 68 lines on the logs that were sent to me.
Old Jun 4, 2011 | 07:31 PM
  #54
drvik's Avatar
drvik
Cueto,
Which macbook are you using??? Core2 Duo or one of the new Sandy Bridge ones?
drvik
Old Jun 4, 2011 | 11:59 PM
  #55
Cueto's Avatar
Cueto
2.4 GHz Intel Core Duo
4 GB 1067MHz DDR3
SSD vertex 2 drive
Old Jun 5, 2011 | 12:00 AM
  #56
Cueto's Avatar
Cueto
its about 2.5 years old
Old Jun 5, 2011 | 04:23 AM
  #57
drvik's Avatar
drvik
So it's nice and quick... Kevin how many lines per second is the maximum your logger can capture?? And Cueto, is your windows partition correctly aligned to a 512K boundary?? Apparently, it's important for both longevity and speed... maybe there's a small improvement to be had this way if it's not already optimised...
Old Jun 5, 2011 | 04:54 AM
  #58
Kevin's Avatar
Kevin
Viktor, I am getting 108 lines per second with my Lenovo Windows 7 64 and Intel SSD
Old Jun 5, 2011 | 05:19 AM
  #59
Kevin's Avatar
Kevin
The log shown below was the motivation to invest and to bring my data logger to Porsche community. I received this from a Rennlister recently. There is just not enough data to see what the engine is doing.
Old Jul 21, 2011 | 02:20 AM
  #60
Kevin's Avatar
Kevin
I have replied to all the previous emails for those that have expressed and interest in the new logger. If I have missed anyone please email me or call me.
Please note that I have purchased 3 IBM laptops for a few guys that wanted me to install the software and get it up and running. If interested let me know.
