GT2 Motor + Subframe mounts
need some input here pls ;
1) are the GT2 engine mounts the same as X73 or harder pls ?
2) Do the GT2 subframe mounts effectively lower the car without impacting on suspension travel ?
Originally Posted by JasonAndreas
I thought X73 was just a shocks and springs upgrade?
Technical Guru
Originally Posted by Zippy
I believe there are some kind of mounting pieces with the kit. Not sure what they are though.
Basic Sponsor
Here is a picture of the X73 motor mount. They are the same as the standard mount except with harder rubber.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
Technical Guru
Thanks for the photo! You didn't happen to check to see how hard the rubber portion of the mount was when you took the photo? A medium durometer thermoset polyurethane poured into a failed/leaking mount might be worth playing around with.
Basic Sponsor
Jason,
No, no data other than seat of the pants impression. You can feel the difference, but it is slight. The car feels a little tighter handling and with the slight increase in engine noise, the overall effect is one of enhanced feedback of driver input.
...A medium durometer thermoset polyurethane poured into a failed/leaking mount might be worth playing around with.
maybe the RS version is a little OTT for additional noise and vibration BigBadBen even took his RS Mounts off again and put OEM back on and I would consider Ben pretty hard core when it comes to tuning . Thats why I am shooting for just the hard rubber ones
