996 Turbo Forum 1999-2005
Pending projects and a few questions
Old 01-16-2009 | 06:39 PM
  #151
jimq's Avatar
jimq
Burgled
Darn Jaime you have passed me up at "only" 66K miles. I havent had any more problems since the alternator died at 63K. My CPO ran out Dec 26 so I guess anymore repairs will be in my garage
Old 01-16-2009 | 06:47 PM
  #152
Wachuko's Avatar
Wachuko
Professor of Pending Projects
Cool
It is those trips to Miami... company would pay for air travel, but I just can't resist taking the car for such a nice long drive Better maximize the enjoyment on the depreciation
Have a great weekend!
PS - 24 of Jan at my place? Helping Ron with the brakes. Let me know.
Old 01-17-2009 | 10:36 AM
  #153
Land Jet's Avatar
Land Jet
Your car is looking great!. Good thing you didn't have Samco hoses in place like me. Took 2 months to get the new snorkel sorted out since a new mold had to be made. I like the look of the tint on your windows.
Old 01-17-2009 | 12:01 PM
  #154
jimq's Avatar
jimq
Burgled
YeaI know about those drives to Miami. I got a blood clot in my leg on my last drive down there
We started to do his brakes at my house last weekend but he ended up just cleaning the wheels and wheel wells. He only had the rear disc and his front ones are also totally shot. He has the stuck on hats on the shoes and I couldnt find my tool to unstick them. I was hesitant about changing the brake lines knowing how stuck mine were. I decided not to go to the Rolex since it starts so late in the afternoon so may come watch youall instead ! I will PM you later this week.
Old 01-17-2009 | 02:23 PM
  #155
Wachuko's Avatar
Wachuko
Question
What I have will not work with the Samco hoses?? Please elaborate...
Old 01-18-2009 | 01:47 PM
  #156
Land Jet's Avatar
Land Jet
The Samco hoses have a higher arch to them and stick up higher. They were keeping my engine lid open about an inch with the original snorkel. To close the lid meant slamming shut and causing the hose to deform. Dan now has the new mold so if you upgrade hoses, you can just get the new snorkel. The new one fits the Samcos fine.
Old 03-02-2009 | 02:14 PM
  #157
Wachuko's Avatar
Wachuko
I never looked into iPod adapters thinking those were not available for the CDR-220... came across a thread in the 993 section today and then searched this forum. Sure enough, there is one.
Order placed today: http://www.discountcarstereo.com/detail.aspx?ID=993
Old 03-02-2009 | 02:21 PM
  #158
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
PIE makes pretty good stuff. They've been doing it for a while now.
Not having MOST (plastic optical fiber) in the car makes it much easier IMHO.
Old 03-04-2009 | 12:06 PM
  #159
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
I have assigned 'sticky' status to Jaime's excellent thread on the 996TT.
It is perhaps the most comprehensive single thread discussing almost all the issues that a 996TT owner might ask.
Hopefully people will come to the forum and see/read the thread before posting questions that have already been addressed.
Thanks Jaime.
Old 03-04-2009 | 05:54 PM
  #160
Wachuko's Avatar
Wachuko
Cool
Thanks Jaime.
Thank you!! I will go over the thread and clean it up a bit. I will also add the links to the detailed threads (in the first post) of the stuff done and review any missing photos of stuff that might be incomplete in those threads.
Thank you again... big responsibility
Old 03-04-2009 | 11:51 PM
  #161
BMo's Avatar
BMo
Dude, an awesome thread and awesome documentation of your beautiful car and your journey. Thanks for sharing!
Old 03-06-2009 | 04:02 PM
  #162
Wachuko's Avatar
Wachuko
Cool
iPod adapter installed to the CDR-220
You can get it from several places. I got mine from here: http://www.discountcarstereo.com/detail.aspx?ID=993
Pull the radio out using the blades
Plug the blue plug, from the iPod adapter, to where the CD changer connects to (if you have a CD changer you will have to decide between one or the other...
I used the ground (brown cable) and + (red with black stripe cable) from the radio to provide juice to the iPod. Quick cut to the shield, solder the adapter wires, some tape, and you have juice. Instructions suggest a switched source to avoid leaving the iPod charging and wasting your battery... I might do that later, but for now I just wanted to keep the ipod charged all the time, plus I plug my car to a battery tender when parked at home.
Route the cable to where you want it... there is space in the back of the radio to route the cable and plug... I need to decide where it will finally rest. Most likely inside the center console.
You need to activate the AUX function in the radio. How to active the "AUX" on Porsche radios with "PT" button (i.e CDR-220)?
1. Turn radio ON Press and hold the "PT" button for about 8 seconds until Becker 1 is displayed. Turn the Tuning **** until AUX OFF is displayed. Press either button located directly under the Arrows on the display to change the present setting from OFF to ON. Turn radio OFF. Auxiliary Audio Input has now been activated.
Connect your iPod (do not make fun of my brick!! everyone gets the new stuff at home and I end up with whatever is left behind!! )
Old 03-09-2009 | 04:30 PM
  #163
Wachuko's Avatar
Wachuko
Cool
Glove box handle fixed.
Best way to get to the bolts is to disengage it from the two shocks:
Using a T-10 tip remove the bolts (5 inside) 3 on each side
What it looks like underneath when you remove the leather cover that holds the handle:
The broken handle:
Remove the two bolts holding the handle with a T-20 tip:
Install new one... install, as they say, is the reverse of disassembly...
Old 03-09-2009 | 04:46 PM
  #164
manny_g's Avatar
manny_g
hey jaime..can you use this ipod adapter cable on cars equipt with MOST? my radio model # is cd 25 and it has a pt button.
Old 03-09-2009 | 04:57 PM
  #165
Wachuko's Avatar
Wachuko
Unhappy
Manny, I think that the only option you have is the expensive route... Dension, Dice, etc...
Edit - CDR-23, correct?? Can't find any reference to a type 25.
Quick Reply: Pending projects and a few questions
