996 GT2/GT3 Forum 1999-2005
Coolant Line Failures- NHTSA
Old 07-11-2013, 06:00 PM
  #166
Gofishracing
Gofishracing's Avatar
Good job everyone. Spread the word about the coolant line issue. So many drivers unaware of the danger. File the complaints if you made a repair. You can search by year- 2001-2007
Porsche asked for an extension on disclosure.
http://www-odi.nhtsa.dot.gov/owners/SearchVehicles
Old 07-11-2013, 06:47 PM
  #167
Larry Cable
Larry Cable's Avatar
Received 3,443 Likes on 2,250 Posts
Originally Posted by Carrera GT
Just had FJ's do the plenum update/recall work. They took an extra minute or three to "nut and bolt" the car and found a bit of an old rat's nest (literally) but no harm done other than a thorough clean up and none of the coolant lines or fittings would budge at all, with no evidence of leaks. I'm running waterwetter, so I'm optimistic short term, but longer term, it will have to be resealed and every "at risk" hose or connector replaced. It is, after all, a three year old car ... then again, my equally "tracked and treasured" 993 (modified turbo, now running zeroed hybrids) has turned more miles, delivers more power and torque and has not needed such careful tendering.
As for the plenum recall, it seems to be VIN-specific and it is a perhaps an RS thing. IIRC, Alex noted the flap failure has caused more than one engine demise he's seen.
oh right this is where the part fails and is ingested into the engine ... BANG!
Old 07-11-2013, 07:22 PM
  #168
NaroEscape
Basic Sponsor
NaroEscape's Avatar
We have a 2004 GT3 with now 59k miles on it. Bought it with 16k miles a couple years ago. The previous 2 owners did some track driving, but not a ton. We only use it for street driving.
So far, no leaks, no issues...but I'm concerned - we take really long trips in it and my wife drives it most days to work....would hate to end up on the side of the road or worse - in a guardrail. Do I REALLY have to drop $3-4k before I can file a complaint?
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
  • Data Analysis & Coaching
  • Drivers Gear
  • Crew Gear
  • Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
Old 07-15-2013, 07:45 PM
  #169
FFaust
FFaust's Avatar
Originally Posted by jtstre
Sent you a PM.
The failure was at a coupling, the main hose pulled out of one end of the coupling. Fortunately it didn't result in any issue other than inconvenience and a lost track day.
Got it, thanks. Was out of town, sorry.
Old 07-22-2013, 11:50 AM
  #170
sithot
sithot's Avatar
Here's a twist on the 996 M96 engines. This is in the latest Panorama which this month went to a large format. (8.5 x 11)
Old 07-22-2013, 12:08 PM
  #171
gman3280
gman3280's Avatar
If I read this correctly you had to have made a repair to be eligible. Is that right?
Old 07-22-2013, 12:38 PM
  #172
sithot
sithot's Avatar
There would be no way to reimburse you for something that hasn't occurred. I have friends with replaced engines out of pocket. I'm sure they are biting at the bit to get reimbursed especially since under warranty the engines were about $9,000. Once all the cars were out of warrant they doubled the price. Nice, eh?
  #173
Carrera GT
Wordsmith
Carrera GT's Avatar
The IMS finding might be a "Ford Pinto" scenario for Porsche -- cheaper to let a few customers blow up engines with coolant bursts and when some ambulance chaser finally gets a class action in favor of the consumer, the net net as seen by Porsche could be the best possible outcome. It might also have been all the complaints here and on other forums sites had the unintended consequence of Porsche discontinuing the Mezger for consumer applications.
Old 07-22-2013, 02:21 PM
  #174
sithot
sithot's Avatar
Default Does Law Matter? Milton C. Regan, Jr.
Consider, for example, the calculations of Ford Motor Company officials in the 1970s with respect to the likelihood that gas tanks in Ford Pinto automobiles would explode when struck from behind by objects moving faster than twenty miles an hour. Internal company documents concluded that the additional cost of making the gas tank safer at higher speeds would be greater than the cost resulting from the estimated 180 deaths and 180 serious burn injuries per year which might be avoided by making a safer gas tank. More precisely, Ford calculated the benefits from a safer tank as the avoidance of costs of $200,000 per death, $67,000 per injury, and $700 per vehicle. Based on the estimated number of deaths,
Injuries, and damaged cars and trucks, the beets came to $49.5 million per year. The costs, however, were $11 per vehicle. With estimated sales of 12.5 million vehicles, these came to a total of $137 million. As a result, Ford officials concluded that redesigning the gas tank was not economically justified, based on concern that higher prices would reduce sales.
As it happened, Ford was in compliance with federal safety standards at the time, not least because it had lobbied hard to prevent higher standards from being enacted. Even if Ford had been in violation of federal law, how- ever, that would have been irrelevant from a law and economics perspective. As long as the cost of obeying the law was greater than the cost of compliance, Ford was justified in con- tinuing to sell Pintos without any design changes.
The law and economics approach to tort law thus reveals two assumptions that are basic to an instrumental account of law. First, law has no intrinsic moral force, but is simply a cost that parties must take into account in deciding how to behave. We use law as an instrument for imposing costs in order to affect these decisions. Second, persons are instrumentally rational, weighing the costs and benefits associated with pursuing alternative goals. Law and economics seeks to make the law a more scientific instrument by relying on rational choice theory to predict how different legal rules will affect behavior.
Old 07-22-2013, 03:47 PM
  #175
Gofishracing
File a complaint Only if you pay for a coolant line fix. Interesting sithot because Porsche knew that had adhesive issues from internal documents. May be the same thing in another form.
Old 07-31-2013, 03:40 PM
  #176
tgavem
tgavem's Avatar
I filed my complain today, ref No 10532876. Did the fix before it failed.
Old 08-06-2013, 09:03 AM
  #177
ChrisF
ChrisF's Avatar
Wasn't Porsche supposed to respond to the NHTSA by now?
Old 08-06-2013, 04:52 PM
  #178
Gofishracing
yes- they got an extention.
Old 08-08-2013, 02:37 PM
  #179
Nugget
Nugget's Avatar
There's definitely still activity. I got a followup question this morning from the investigator asking for additional details regarding my incident report (#10492870).
Old 08-08-2013, 04:10 PM
  #180
AudiOn19s
AudiOn19s's Avatar
as did I. asking if mine failed in a turn or going straight.
Quick Reply: Coolant Line Failures- NHTSA
