996 GT2/GT3 Forum 1999-2005
Coolant Line Failures- NHTSA
Old 06-16-2013, 05:11 PM
  #151
Bailey-86-MA
Bailey-86-MA's Avatar
I will be filing. Thanks.
Old 06-16-2013, 06:40 PM
  #152
Gofishracing
Gofishracing's Avatar
Guys- I'm at the point with this that we should fix our lines - file complaints- and expect some compensation in the future as far as some financial reimbursement. Safety first issue. I contacted the investigator from NHTSA He is not allowed to give me a count of complaints. I wish more PCA regions were pro active. I see some changes in the Tech forms for track events - an alert- which means to me a real problem - but these things take time- Deadline for Porsche approaching to disclose everything to NHTSA July 11.
File Type: pdf
Old 06-16-2013, 07:02 PM
  #153
Carrera GT
Wordsmith
Carrera GT's Avatar
Absolutely. I'm taking the opportunity of the plenum recall to go ahead and re-glue the coolant fittings and have a trusted master Porsche tech go over the car nut and bolt.
Old 06-21-2013, 03:50 PM
  #154
pill pusher
pill pusher's Avatar
Filed my complaint. Mine failed driving on the interstate~
Old 06-21-2013, 06:43 PM
  #155
DaxBushmeyer
DaxBushmeyer's Avatar
Done
Old 06-24-2013, 04:39 PM
  #156
Larry Cable
Larry Cable's Avatar
Received 3,619 Likes on 2,350 Posts
plenum recall??? - I must have been hibernating?
Old 07-03-2013, 12:02 AM
  #157
Texas RS
Texas RS's Avatar
2011 GT3 RS
I had a failure at DE event, fortunately failure occurred at the end of the session as the car was on a cool down lap.
Just filed.
Old 07-03-2013, 08:17 AM
  #158
FFaust
FFaust's Avatar
Originally Posted by jtstre
2011 GT3 RS
Just filed.
Could you be more specific? Do you know what failed (hose, coupling, front, back)? If a coupling, do yo know which one?
We were led to believe the the newer cars had been upgraded at the factory (longer couplings, better adhesive), but it's hard to tell whether this is an urban legend or not since there hasn't been an official announcement.
Thanks,
Old 07-03-2013, 09:09 AM
  #159
Only1Buck
Only1Buck's Avatar
@ FFaust when you refer to newer cars which models and which years?
Old 07-03-2013, 04:46 PM
  #160
FFaust
FFaust's Avatar
Hard to say, remember, nothing was said officially. It was kind of implied that the 2010 - 11's and up Mezgers had been 'fixed' ???
Some P dealers made some affirmations, but unfortunately they are surprisingly not always in the know about these things... or in denial... or under gag orders.
Old 07-04-2013, 01:06 AM
  #161
Charles@dundonmotorsports
Basic Sponsor
Charles@dundonmotorsports's Avatar
I know this is not 100% related but I had a 2008 cayenne s towed in last Saturday to me that had one coolant fitting blow out on him and it caused a 3 car wreck. So this is probably going to be a problem on the cayennes as well.....
Old 07-07-2013, 12:58 PM
  #162
Texas RS
Texas RS's Avatar
Thanks,
Sent you a PM.
The failure was at a coupling, the main hose pulled out of one end of the coupling. Fortunately it didn't result in any issue other than inconvenience and a lost track day.
Old 07-09-2013, 11:19 PM
  #163
Texas RS
Texas RS's Avatar
Default Coolant line failure 2011 .2 GT3 RS
Attached is a photo of the failed hose.
Old 07-09-2013, 11:56 PM
  #164
jellonailer
jellonailer's Avatar
I think the hose failed around here.
Obviously caused by overstressing your engine trying to get past that 964.
Old 07-10-2013, 03:16 AM
  #165
Carrera GT
Wordsmith
Carrera GT's Avatar
Just had FJ's do the plenum update/recall work. They took an extra minute or three to "nut and bolt" the car and found a bit of an old rat's nest (literally) but no harm done other than a thorough clean up and none of the coolant lines or fittings would budge at all, with no evidence of leaks. I'm running waterwetter, so I'm optimistic short term, but longer term, it will have to be resealed and every "at risk" hose or connector replaced. It is, after all, a three year old car ... then again, my equally "tracked and treasured" 993 (modified turbo, now running zeroed hybrids) has turned more miles, delivers more power and torque and has not needed such careful tendering.
As for the plenum recall, it seems to be VIN-specific and it is a perhaps an RS thing. IIRC, Alex noted the flap failure has caused more than one engine demise he's seen.
Quick Reply: Coolant Line Failures- NHTSA
