ATE Cayenne S Rotors for 996 GT3 - Where are they?!?!?
#61
ATE is still available here in Ontario. Just picked up a pair today.
#63
I have some for cheap( $50 bucks) that have less than 15k miles and 3 track days.
Took these off because they weight A TON. After going back to lighter 2pc rotors
not sure what i was thinking getting these on.
#65
My club sport suspension is so much nicer / steering is much better after
getting rid of these anchors.
#66
I've had/used different types of rotors for years. I never noticed any increased wear on anything. What "vastly increasing wear and tear" are you seeing? And most important to me, I have no noticeable speed or lap time difference. I can win my DE with heavy or light rotors! YMMV.
In all seriousness, it's about cost/benefit for me. Any marginal improvement by reducing weight by only a few pounds per corner doesn't make up for the cost differential to me. I don't see any difference in wear/tear/speed/etc. Sure, they're heavier. But they are $100.
-td
-td
#67
-td
-td
But i noticed a huge difference in car characteristics between heavy /light rotors.
I do drive my car on the street mostly not just track. I suppose that maybe the difference between you and me where i can notice it with my aftermarket coilovers. Flat smooth surface vs. bumpy crap CA hwy surfaces.
#69
do you drive your car on the street? did you feel your suspension ride smoother on street roads ? etc. that is where i noticed the biggest difference for me.
#72
Completely stock 6 GT3. Can't tell the difference except my wallet is not as light. Admit to not having won a DE in a long time however
#73
650 front / 1050 rear. KW CS.
I wonder if it has to do with the fact that mine is AWD, and you already feel that load with that system on ? Who knows, thing is , i noticed a drastic difference.
That said, you guys should get my cayenne rotors as backups for cheap then
#74
F1CrazyDriver is obviously a more sensitive driver than I am; I've always admited how insensitive I am - still respectably quick but numb to slight changes. E.g. ask me if changing camber .5* made a difference and I'll probably reply "what was my time and I'll tell you." I've seen plenty of guys on forums claim that a 5# lighter wheel on a 3200# car "made such a dfference!" I'm like, yea, you and Ayrton Senna.
