GT3 Competitiveness in TTS with NASA
#61
I've had a bad case of GT3itis for a couple of years, came very close to pulling the trigger on a White '05 last year (drove it all day and it was a blessing/curse), but it had issues and a bad past. Now, I've a local GT3 haunting my dreams, when I"m able to fall asleep, and I don't think I can resist any longer.
My C5Z is a pure beast, almost perfect for me, but I haven't had the "connected" feeling with it, or my past magnacharged Z, as I've had with other vehicles...'05 Elise was purely telepathic but too slow and cramped.
I believe the 6GT3 will be the dance partner I've been searching for all this time. Say a little prayer for me and I should be joining this forum as more than a lurker...
Perhaps, but after watching your video, you know enough about how to hustle that RS around a track!!!!
I'm done trying to be the fastest. Now it's all about the fun and sharing that fun with my students.
Be good,
TomK
#62
I just found out I'm racing against the 'Nationals' STU (camaro) winner next weekend in his ST2/TTS Corvette at Cal Speedway. He's very fast and kicks *** in T1 with the Corvette. We've never run against each other before so this should be really interesting. CS favors the high HP Vette, but the Porsche should outbrake him and hopefully handle better on the infield. Tires get very hot on the banking, my Yokohama Patron-Cup slicks should last longer than his DOT Hoosier's, R or A compounds. I'm really looking forward to the matchup....
#65
Hell I'm nervous about it already. I just switched to Clubsports and went to softer springs (550/700) so I have no idea what I'm bringing to the table. Test-n-tune on Friday should be interesting....
#66
Nice - waiting to hear back.
I missed out on Yoko slicks, by the time I called them it was all over which is too bad!! Sticking to Hoosiers for now.
I continue to have very bad thoughts about gutting the car and putting a cage in it to go ST2. Just can't bring myself up to really make that call. Need to spend more time behind the wheel and get used to it. Good thing there is no rush.
#68
A couple of things. I just tried going stiffer at my last race from 700/900 to 900/1100. The car was very harsh and unforgiving. It may or may not have been faster, but it wasn't any fun to drive at just 2600lbs. w/driver. So I thought lets go the other direction and try softer. I'll now have the cannisters to help balance the car via pressures. If I don't like it I'll go back up to 700/900 but doubt I'd ever run the stiffer springs again....
#69
To get a GT3 to the level of those Vette's would take a lot of money. They are on the very edge of the class, with custom gearboxes, and some of them are getting extra HP to add by running 275 rear tires so they are actually 8.4:1 weight/power ratio. Don't know if that's feasable on a GT3.
You'd basically have to get your car to early 996 Cup prep, then you could beat them.
Hoosier R's are not competitive vs the faster cars. A's don't last long, but then again, you don't need them to. Once you are fast you will catch traffic in a couple of laps anyways. If you can win in your region and there are enough entries, you could win some more tires and save money.
#70
The fastest 2 cars in TTS at Miller last fall were a RX7 and a Honda Civic. The fastest Corvette, who won in 09', was a 1/2 second back. In 09', Corvettes did win first and second with the Honda in 3rd. I'm fairly confident I would have won had I run as my fastest ST2 race lap was faster than the fastest TTS lap (same class parameters).
As I said at he beginning of this thread, a well driven GT3, set up light and at the class limits, can beat a TTS Corvette. They're close in weight and HP, and the GT3 with proper suspension should handle better and out-brake the Corvette so why wouldn't the GT3 win? And a GT3 could run 275's square if someone wanted to experiment. Big wing, full stiif front, full soft rear, now that might be a hoot.....
#71
The fastest TTS Corvettes were not at Miller. They WILL be at Mid Ohio.
#74
I think Jr had a good comparison versus Ken's times year before. Ken's car is pretty damn quick. Either way this should be a very good ST2 field and I most certainly hope Jr will have a great result. I'll be there for the Spec E30 race, so I'll be on the sideline cheerleading for ya!
#75
Amen!! I have been a passanger in that beast and with Joe behind the wheel long enough at that track, I could see him breaking into the low 1:36's if not the high 1:35's if the planets are all lined up.
