996 GT2/GT3 Forum 1999-2005
PCCB SAFTEY ISSUE
Old 10-11-2006, 09:04 PM
  #31
MJones
MJones's Avatar
Originally Posted by DanH
Isn't there now a Gen3 on the 997 which has gone back to a regular perforation pattern?
FWIW
In the "Fact Book" they refer to them as:
Enhanced Porsche Ceramic Composite Brake
From the Turbo Product Info Guide.
The most important changes resulting from this optimized disc technology
relate to the shaping of the inner cooling ducts to achieve increased ventilation accompanied by enhanced brake cooling and rigidity and the composition of the employed materials, resulting in increased wear resistance.
The overall outcome is an increase in the performance of the brake system and a further extension of the brake system’s service life.
From he GT3/RS brochure:
To ensure maximum cooling during extreme brake usage,
the internal vents within each disc are subject to a process
of continuous development.
The number of cooling channels has recently been doubled,while
a new vent geometry offers a better flow of air through the
disc. With more cooling channels, there are more internal walls creating greater structural stability.
Externally,these modifications are clearly visible in the form of
a modified drill-hole pattern.
Old 10-11-2006, 09:48 PM
  #32
gweedo911
gweedo911's Avatar
Originally Posted by MJones
FWIW
Enhanced Porsche Ceramic Composite Brake:
I assume this is the Enhanced PCCB. The cross-drill pattern is different from Gen 2 PCCB. Correct?
Old 10-11-2006, 10:12 PM
  #33
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
Colm - I will answer your question this way. Yes, racers take spares. When spare ceramic rotors cost 8700 bucks each and, don't last longer on the track than old fashioned cast iron ones which cost 400 bucks each, guess which ones the race teams use? Porsche made a big mistake on the Gen 1 PCCB as fitted to 996 cars used on track by experienced drivers. On the 997 Cup cars which come with ceramic brakes as standard, a number of the pro teams have switched to metal rotors because the ceramics are not cost effective. If the ceramics cost only a bit more than the metal versions, there would be no issue. When one has to pay something like 35,000 dollars to replace 4 brake rotors, a much longer life is a reasonable expectation especially in view of the claims made by PAG that an H mentioned.
Cosmos - I posted the care and feeding of PCCB about 3 years ago. I managed to make mine last longer than most in spite of intensive track use. I replaced pads whenever they were approaching half thickness. It is also important to make sure the holes in the rotor are not plugged with pad material etc. Notwithstanding my care, at around 12000 miles the rotors failed, all 4 of them. The fronts failed as Paul described, delamination of the surface. The rears looked ok on the wheel side but the inner side had chunks missing!
Best,
  #34
roberga
roberga's Avatar
I will send a picture of mine over the weekend. Mine have difference patterns.
Old 10-11-2006, 10:13 PM
  #35
MJones
MJones's Avatar
YES
Here is a progression of drilling thru the generations
Old 10-12-2006, 01:30 AM
  #36
AllanJ
AllanJ's Avatar
Hi Bob,
I'm at 10K miles with this pccb setup so I'll be keeping an eye on these rotors. I guess I'll be sourcing some steel GT3 Cup rotors as replacements. At the moment, my '04 GT3 will be used for 95% street driving. Some autox and DE events will happen but next year I'm too swamped with other stuff to get to driving events much.
What pads should I use for primarily street use with the new steel GT3 Cup rotors? I'd like to avoid noisy, squeaky brakes.
Thanks,
Allan
2004 GT3
1975 914-6 3.0 conversion
Old 10-12-2006, 05:33 AM
  #37
PaulRothwell
PaulRothwell's Avatar
Replaced with Alcon steels now....still no joy from Porsche.
Old 10-12-2006, 10:39 AM
  #38
DanH
DanH's Avatar
YES
Ah perfect, some evidence to back up my understanding of this. What I find remarkable is that gen3 seems to have dropped the 'revolutionary' drill pattern. Or did they have a job lot of CGT disks left over in the correct size for the 997?
Old 10-12-2006, 11:38 AM
  #39
MJones
MJones's Avatar
FWIW
Carrera GT have the Gen1 drill pattern...
Each disc contains a teltail
US Patent 6776265
Device for indicating the total load in the case of brake disks made of carbon-fiber-reinforced ceramic material
Patent Drawing of Gen2 disc
US Patent 7100748
Internally ventilated brake disk with curved cooling air ducts
Old 10-12-2006, 02:02 PM
  #40
PaulRothwell
So....why dont Porsche admit the problem?
Old 10-12-2006, 02:08 PM
  #41
DanH
DanH's Avatar
That's not a serious question is it?
Old 10-12-2006, 02:41 PM
  #42
cosmos
cosmos's Avatar
Received 1,115 Likes on 616 Posts
And they say you Brits don't have a sense of humor.....wait....humour, sorry.
Old 10-12-2006, 03:22 PM
  #43
DanH
DanH's Avatar
What the hell?!?!?! It's Americans who are humourless and take themselves too seriously!
We gave you monty python you gave us David Letterman. You owe us big time
Old 10-12-2006, 03:33 PM
  #44
Holger B
Holger B's Avatar
Waaay OT: You want humor? http://www.youtube.com/watch?v=pa_7P5AbUww&eurl=
Old 10-12-2006, 05:30 PM
  #45
roberga
roberga's Avatar
MJones: My "new" front are the middle picture. GEN II
Quick Reply: PCCB SAFTEY ISSUE
