Body in White's 996 GT3 Journal
#76
I see both. but the correct way is to mount the 3pt belt to the seat upright (the block).
you can also mount the 5/6 pt belt to the same bolt. I also seen THAT BOLT replaced with an EYE BOLT. the eye bolt secures the 3 point belt like a regular bolt, and the 5/6 pt belt has a clip and clips to the EYE part, the clip then locked out with a little cotter pin.
#77
Please do, I'd like to see them.
#78
I ran down to my shop yesterday evening to take care of the remaining maintenance items left on the car: cabin filter and plugs. I enjoy the mechanical maintenance more than exterior detailing and interior work, so I was excited to get this done.
The plugs only had 1,300 miles on them, but they had hit their 4 year recommended time limit so I swapped them. Plug changes on GT cars is trivial, so I don't mind -- it's cheap insurance.
As I suspected, all the outgoing plugs looked brand new... this car hasn't seen much action in the last 4 years. I'll change that.
The cabin filter was last done 4 years ago as well, so I swapped that out and replaced the hood struts that were starting to weaken.
I had hoped to take the car out today for a long drive before it goes to Sharkwerks next month for the line pinning & LSD, but it was raining (and cold enough to be sleeting on some of the route.) Oh well, maybe later this week.
plpete84 (02-25-2022)
#79
When I first had my Guard plates installed I thought it did nothing—at least on the street. However, when I began attacking corners more aggressively the car's back end is planted so much better. There is no drama.
JJT (02-23-2022)
#81
The PPF guys dropped by this week to cover the carbon fiber door sills that hadn’t arrived by the time they did the exterior install on the car.
Thanks to @spiller for the tip, I bought a 997.1 GT3 Indoor Car Cover (p/n 997-044-000-09) to accommodate the RS wing. It fits perfectly, but the hang tag denoting an RS bothers me… so I whipped up a new one. Problem solved. If you all are as particular as me, I’ve attached the file below. Print it at 1.75 inches heigh, by 3.25 inches wide.
smceo (04-22-2022)
JJT (03-08-2022)
#85
Yes, it is very similar to yours. Flipping through the magazine, it reminded me of this fantastic thread.
#86
IMHO, the best part of this thread was the absolute "revelation" about the efficacy and utility of high-end steam cleaners! Just pulled the trigger on a used vx5000! This is not going to be good for my marriage as I spend hours in the garage cleaning every nook and cranny on my cars!
#87
#88
#89
Want me to really blow your mind? Best way to clean the HVAC system: pull the cabin filter and steam all the vents. Install a new cabin filter. It’ll blow out any dust or funky smells.
nexus77241 (10-16-2022)
#90
Went down to my shop to wash the car before it heads over to Shark Werks next week, and waiting for me was the driver’s side arm rest cover that I ordered back in October. I honestly thought the order was canceled, so it was a welcome surprise!
It was an easy swap, pull the pin circled in red, swap in the new one and reinstall the pin. It’s gratifying to have a perfect door card.
The following 2 users liked this post by Body In White:
SupraSaiyan (03-27-2022),
The Duke (03-28-2022)
