Durametric Diagnostic tool-Reset Airbag alert
I just received my Durametric Diagnostic kit and I'm trying to figure out how to clear the Airbag alert code. Does anyone have experience with the tool and specifically how to clear this code? Car is a 02 996 TT. Thanks.
Click the Airbag menu item on the list on the left. Then click "clear fault codes" from the drop-down list. Use the dialog that pops up to clear the fault codes.
Received 1,192 Likes
As long as the airbag sensors have not detected something wrong with the airbag system then the reset will clear the airbag code and that is it. It should not come back on as long as the airbag system is okay. If it comes on again then something is wrong with the airbag system. You did not say why it came on in the first place?
My airbag light was coming on due to a bad seat belt buckle in my 1998 Boxster.
There is a thread about this hear as well. https://rennlist.com/forums/boxster-...hread-faq.html
This is helpful, thanks. I can't pinpoint what happened. I parked the car in my garage and everything was fine. The next morning I turned on the ignition and the airbag indictor came on.
If you have a different code, you may have a different, and perhaps more critical, problem.
The code was for the seat belt buckle switch which has been reset. We'll see how long it stays off. Next step would be to perform the clean and lube of the bucket per your suggestion.
Unfortunately for me, the cleaning of the buckle didn't work, it was just worn out. I had a friend who is a mechanic for Porsche try to reset it and it immediately came back on. Leith Porsche had the cheapest prices I could find for new buckles and since my car had the upgraded ground wiring I didn't need the extra harnesses.
I used DeoxIT when I cleaned mine.
Interesting, I didn't realize that could be done as I would have went that route. Would have saved me time, headaches and a scratch on the door.
For safety.
Seems like disabling it would create a potentially unsafe condition. Not sure what the default behavior of the system would be in a crash, but I wouldn't modify the airbag system based on advice from the internet. Just sayin'.
I've had my seatbelt check programmed to be off for a few years now But mainly so I can swap to race seats without issues.
Two-stage airbags are certainly in use.
A quick google search found this at Edmunds.com:
"Advanced Airbags:
...By the early 2000s, some automakers introduced these new airbags, calling them "advanced," "smart," "dual-stage" or "multi-stage."
These airbags were created primarily to reduce the risk of airbag-related injury or death to children and small adults by either deploying with less force or not at all, depending on the situation. Sensors, usually located in the seat and seatbelts, sent signals to the vehicle's computer providing information such as the weight and seating position of the occupant and if he or she was wearing a seatbelt. In the event of a collision, the computer then made a split-second decision on whether to deploy the airbag at full force, reduced force or not at all."
