Looking at a 2001 996 with a Blown Head Gasket
I currently own a 88 944 Turbo that I just did a maintenance overhaul to., ie cam tower reseal, all belts (cam, balance belt, alt, p/s), all 16 rad hoses and clamps, water pump, vacuum lines, ISV hoses, all sway bar bushing replace, rebuild power steering unit, new rollers/tensioners/front engine oil seals, oil pump gear drive, injectors rebuilt, and now being driven on nice weekends and work days.
And with that said, a 2001 996 carrera 4 convertible w/184k miles pops up for sale with a blown head gasket. My question is, its cheap---> $5k, is it worth it with a blown engine?
I don't have the option sticker available, but it has full leather, manual, triple black, no nav, aftemarket rims(victor equipment), alpine aftermarket stereo, non-sport seats, and the black hard top.
I will assume no service records, so is this a walk away 996? I am comfortable doing work on the car, I just don't need a major headache beyond swapping engine's.
Thanks guys for the advice and words of wisdom.
A roller with that high mileage I would say ~2-3k. Most likely it's not the head gasket but a cracked head or worse though. The head gaskets (MLS) are known to be totally robust for these cars.
Generally speaking M96 engines don't blow head "gaskets" (they actually don't have head gaskets per se' just a permatex like material or "liquid gasket") - more likely they develop cracks in the head(s)... If they're not too badly damaged, they can be fixed, but without in depth knowledge of the particular motor in question it's a crap shoot...good luck
^Yup^ - I thought the head gaskets were the same Glad you beat me to the punch! At least I got the cracked head part right...
Should I not even entertain an offer to the current owner?
Now I know why $2-3k for the roller, its a major crap shoot, but at least if the engine is too far gone, then I can part it and get my $$$ back.
Hopefully
Captain Obvious
Super User
Super User
It's worth $5K. You might get lucky (like I did) and the engine is fixable but better to prepare for the worse (engine replacement). A good used engine is $7-up, then what if the transmission is gone or needs to be fixed? Sounds like you are a handy guy, go have a good look at it, see if you can at least test the transmission. Replacing just the bearings and rings is $2K in part alone (I'm doing that to mine right now). If you have the money to finance this then go for it but to get this car back on the road will cost from a few thousand to many many thousands.
There are no cam cover gaskets in these cars either. Just sealant used on the cam covers. And if you talk to Jake Raby I think he will tell you that he has never seen a blown head gasket on a M97/97 engine. If a seller or mechanic is saying a blown head gasket they are covering something up or don't really know what they are talking about.
Is there coolant in the oil or vice versa?
allcool (07-03-2023)
Here's to trying.
His mechanic said it was a blown HG, but I call BS, he knows what he has on his hands, a bad 3.4L. We will see, i'll speak with the owner tomorrow.
996-CAB (07-03-2023)
Temping, but i know from previous 928's, it could be the biggest money pit ever.
With that mileage the cylinders are out of round requiring sleeves & new pistons (bigger). I assume it's losing coolant somewhere, so cracked cylinder or head.
