996 Forum 1999-2005
My turn in the barrel is over......
Old 04-09-2015, 01:58 PM
  #61
Sneaky Pete
Sneaky Pete's Avatar
So a little update. I spoke with Jake yesterday afternoon. All parts that I bought for the motor have been installed. Fisters, new NHP 200 cats, used X51 headers, new IPD 82mm plenum and a used GT3 82mm throttle body. They fired the car up and it spit and cursed. Ran fairly sour. The culprit looks to be the TB. They are swapping it out with another and I hope to hear something today. I'm also reminding myself that this car has sat for some time and stuff happens in the interim. Stay tuned!
Old 04-09-2015, 03:28 PM
  #62
alpine003
alpine003's Avatar
Pete, just wondering what your rationale was to get new IPD but used GT3 TB considering they are fairly cheap?
Old 04-09-2015, 04:08 PM
  #63
Sneaky Pete
Saw a deal and because I'm cheap
Old 04-09-2015, 04:15 PM
  #64
alpine003
alpine003's Avatar
Nothing wrong with that, we all gotta skimp somewhere to get other things. I'd rather you cheap it out on that so you can get good tires.
Not sure where you shop or look but new 997 GT3 TB's can be had for around $265 shipped. Cheaper than non gt3 tb's.
Old 04-09-2015, 04:55 PM
  #65
Sneaky Pete
Do tell..........what store you speaketh of?
Old 04-09-2015, 07:13 PM
  #66
alpine003
alpine003's Avatar
I remember seeing it from a few vendors before when I was contmplating on upgrading my IPD to the GT3 version.
Here's one example: http://www.ebay.com/itm/Porsche-997-...p2054897.l4275
Old 04-10-2015, 01:32 AM
  #67
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
All is well, its happy and healthy and went for a 10 mile drive today and saw the first 3 thermal cycles. Tomorrow it'll see 2 more thermal cycles and then Monday the first 55 mile stint up and down the mountain. It'll thermal cycle twice Monday as well, then it;'ll see the dyno for some baseline part throttle runs Tuesday morning, then a thermal cycle and then 5 full power runs that afternoon.
That will tell us IF it will need a tune, and then where I'll need to tune it with these sub- systems. The car will then be tested the remainder of the week, if it needs my tune that usually takes 3 days on the dyno to get it perfect with a few runs and thermal cycles everyday. The last piece is the final 55 mile drive followed by my invasive inspection, and a baseline used oil sample.
The throttle body was junk, swapped it and all was well right off the bat.
Need to make that Honda a 500X 3 wheeler.
Too easy and generic.. I have another 200X core engine that I want to build up with an LN cylinder, my own cam and some trick head work. That whole swapping another engine on doesn't do it for me, I'd rather build the little beast my way and give it some real character.
Here'e the beast, barn find where it had been since 1985! Note the twist throttle, that makes it a lot more fun!
Old 04-10-2015, 09:23 AM
  #68
Joe Ricard
Joe Ricard's Avatar
I remember nearly killing myself on one of those back in the 70's . You be careful on that thing.
Old 04-10-2015, 04:08 PM
  #69
JMLavoie
JMLavoie's Avatar
Yes, those were real widow makers.
I'm surprised they are still around and I would not classify it as a great barn find.
Easy in the corners, Jake!
Old 04-10-2015, 05:03 PM
  #70
Imo000
Captain Obvious
Super User
Imo000's Avatar
Tbey are not THAT dangerous. I've ridden an 200 and a 250 many times. You have to do something idiotic to flip it. My kidneys liked the 250, is had rear suspension.
Old 04-10-2015, 05:17 PM
  #71
Carmichael
Carmichael's Avatar
Wow, you mean even with a .2 liter bump in displacement, massaged heads, a throttle body, plenum, X-51 headers, and stock-ish exhaust, the car doesn't need bigger injectors, and possibly not even an ECU tune?
I know I'm coming from a world of forced induction (I had to go from 320cc to 450cc injectors [and a tune, of course] on my R53 Cooper S with 222 FWHP), but that sounds pretty crazy. The OE injectors must be pretty huge, and the ECU must be pretty flexible.
Jake, those heads are a masterpiece. Those valves are gorgeous!
Can't wait to see the dyno numbers!
Old 04-10-2015, 06:56 PM
  #72
alpine003
alpine003's Avatar
2 wheels in the front is a lot more stable when cornering than 1 wheel front/2 wheel rear combo hence why it can be dangerous if driven hard.
Jeremy has a good demonstration of this on the Reliant Robin...
Old 04-10-2015, 09:40 PM
  #73
Hardback
Hardback's Avatar
3 wheelers are rad. My twin bro and I cartwheeled a number of them over the years. Nothing like pushing the rear end around in turns crossing up the bars.
Pete, getting close huh? Track season is here... Just sayin
Old 04-10-2015, 11:25 PM
  #74
Sneaky Pete
Ha no kidding. I need to do some break in first. And not willing to break a warranty. I haven't tracked sine April 2013 when the original motor went kabloom...so yep it's killin' me.
Old 04-11-2015, 01:29 PM
  #75
Imo000
Captain Obvious
Super User
Imo000's Avatar
Rolling a Reliant Robin - Top Gear - BBC - YouTube
Yes of course 2 wheels in the front are a lot more stable. BUT have a look at where the driver is sitting in that clip and the large mass that's above him. The Honda Big Red's are not THAT unstable. If yo wear a helmet, you should be just fine if it ever flips. I bet most of the fatalities had no helmets. They are as safe as a Corvair or a 911 without stability control.
Quick Reply: My turn in the barrel is over......
