blown engine
05-14-2015, 03:29 PM
It will be interesting to see if there are any bits missing from either the IMS paddle or chain guides as well.
05-14-2015, 03:42 PM
Quote:
Originally Posted by
alpine003
Oh yea, no worries. I'm gonna check every inch of the engine.
05-14-2015, 07:10 PM
That's a nice 996, I looked at it a couple days before you bought it. Too much metal in the filter for my plan. Good luck with the project!
05-14-2015, 07:14 PM
Thanks and yes, I would need some luck
05-14-2015, 10:55 PM
Thanks for posting the diagram for us students.
05-14-2015, 11:24 PM
I'm learning here myself
05-15-2015, 12:03 AM
Good stuff! I look forward to seeing what has gone kaflooie.
05-15-2015, 01:25 AM
the 5 big ferrous pieces look a bit like gear teeth. Doesn't the 3.6 use Hyvo chain between the IMS and crank? (image from Ford)
05-15-2015, 02:17 AM
Possible. They look like they had been ground multiple rounds for a while before they landed on the oil pan. I wonder if it's something broken inside the scavenger pumps.
05-15-2015, 02:45 AM
7th Gear
Do you know if you're going to rebuild yet?
05-15-2015, 02:57 AM
Not yet and it all depends on what are damaged e.g., if the crank is damaged, rebuild will be out of the question.
05-15-2015, 05:05 AM
Jake never posted the photos from my motor's autopsy, but apparently even the crank was destroyed. Would have liked to have seen the pix.
05-15-2015, 10:48 AM
Cuda911
Wasn't that part of the deal?
05-15-2015, 11:47 AM
Former Vendor
I see chunks of piston and rod/ main bearings too.
05-15-2015, 01:40 PM
Flat6 Innovations
Thanks Jake assuming you are referring to my photos (cringely's engine).
