True enough but the symptom "rocks in a hub cap" indicates a high probability, though being able to drive the car after hearing that makes one wonder if it might be something else?
If you can drive the car, its probably not the imsb. Maybe the chain for one bank went. I have heard of the motor running on 3 cylinders in a turbo due to a broken chain.
Wow, so car goes 77k on factory IMS and 23K on expensive LN IMS bearing?
Makes me wonder about the quality of the install (if it actually was installed)
Ditto. California car so, presumably, no severe cold weather starting risk across its history. Bad install of IMSB; water pump fragmentation; timing chain breach? Even if the cylinders scored, is this is foreseeable outcome? Odd.
Surely you would notice some kind of power loss. How far did you drive it?
Possibly as far as 40 miles. Didn't stomp on the accelerator, but going up a 10% grade, didn't have to hit the gas, just tickle it.
I've attached a photo of the (taken apart) oil filter showing the metal filings caught by the filter—if that will help (especially if someone knows what a trashed IMS bearing does to the oil filter). sorry for the size of the image
There no way this is IMS related. The motor would have seized up from loss of oil. Something else caused this. No doubt damage was done after 40 miles.
I've had a similar engine issue.
The chain rails debris should be brown/dark brown
Magnetic debris -maybe IMS
Non metallic glitttering debris = crankshaft/rod bearings
White/grey granular - look at it under a microscope to see the shape of the particles. ceramic should be shards ,not spheres?
also, no loss of oil pressure during the drive to repair shop, normal water temp, no check engine light or any dashboard indicators. If it wasn't for the noise, I wouldn't have been aware of any problem.
This is not making sense......at all. Maybe you ran over a squirrel and it somehow got lodged in your airbox.....and that squirrel is super pissed! I would be to after 40 miles.
So what exactly is your mechanic saying in order to charge $19K for a installed motor? That part isn't clear unless I mis-read something.
