How do I fix this?
How do I fix this?
Don't ask me how it got this way. I just want to fix it. The tab on one side for the lid is broken. Suncoast sells this:
http://www.suncoastparts.com/product...Code=POTE996IN
Would this be an easy install? Thanks.
It shouldn't be that tough plus you can remove the piece and study it at a table. When the part arrives use it as more schooling to determine how it's attached and what fasteners are holding it. If it still doesn't make sense to you, just don't mangle it learning. It's light enough you can mail it to someone who already had one apart.
There are 2 ways to fix this. Assuming you still have the mirror you can order that part and follow these instructions
http://www.renntech.org/forums/topic...2?&#entry48358
Or you can order the non lighted version for a lot less, remove the cover and swap it out
http://www.6speedonline.com/forums/9...ror-cover.html
Thank you! I think I have actually seen that DIY before. Somehow, I must have forgotten.
If I could find the house I want down there you could drive over to it and we could fix it over a beer! Oh well one of these days I'll find one...
PS This is a good item to try to find from a recycle place, might even cost about the same in the end.
The visor does pull off so you can look at it without being cramped up in the car. Part on order, good track day, life is good.
Looks like your visor swivels. My 02 Targa visors only flip down, is this normal? I find it annoying that I can't drop it down and over next to the drivers window when the sun is to the side.
