Different Approach to DIY IMSB Retro / Parts and Pics
#32
Well done for taking this on, I’m still on the std bearing and after reading your removal and the Casper data, I am more comfortable to leave the std bearing in, change the oil regular and keep it topped up to the max, so the bearing is constantly sitting if fresh engine oil.
When the clutch finally dies I might change it out for a CH bearing, but not as a panic move before.
#33
Are you eligible to ask for the lawsuit discovery documents? There is probably a lot of interesting info in there. I'm sure your miles are low enough, is your car new enough?
#35
Anxiously awaiting your parts inventory postings you mentioned above... I have extended warranty thro Sep this year, after which I want to dive into this project over the winter break... so want to see what you show as LNE alternatives...
#36
The standard/OEM bearing is sealed on both sides so the engine oil is not a viable lubricant for it. This is one of the design flaws. The only way for the engine oil to act as a lubricant for this bearing is to remove a seal. I did this on my OEM bearing (dual row) back in 2009 before the tools and technique for removing a dual row bearing were perfected.
#41
Hmmm, the same experts that said you couldn't change the IMS bearing w/o disassembling the engine? The same experts that used a $12 (probably cheaper back then) sealed bearing to support a critical part of the engine?
Alp, sometimes "experts" miss something and sometimes they just don't care. Kind of like how some NASA employees warned the experts about sealing ring integrity for a at near freezing temperature Challenger space shuttle launch?
I would love to read the internal memos and emails between the Porsche employees concerning the IMS problems.![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
#42
Skoot
#43
The bottom line is that it was a huge error to use a SEALED deep groove ball bearing inside an oil bathed location of the engine, regardless of the quality of the bearing. Any person with common sense should have known that the seals would be compromised, then hinder proper lubrication in this enviroment.
And of course, it's your car, do what you want, etc, etc, but I have to agree with Casper and JR about oil side open and the other tube/shaft side closed, IF you are going with an open design. Having the tube side open will not increase any flow or circulation, unless you spend all of your driving going up and down short steep hills. Otherwise it is a rotating dead zone tube, with unpredictable consequences of possibly filling with oil on a long uphill, robbing that capacity from the system, or if the fill is corrected for that tube capacity, then over filled on a down hill, as the tube empties. The effect of the mass of the oil in the tube as it is rotating at high rpms while cornering and causing possible deformation is another unknown. I'm not sure what my replacement will be when the time comes (clutch replacement, or indication), but for a lower cost Solution, a bearing with far better seals, as Pelican seems to have embraced, (I mean, seriously, in 2013 no one makes a truly sealed bearing that can work in partial submerged 250F oil?) makes as much sense to me as a splash lubricated CH bearing does.
#45
There is a fairly lengthy thread on Pelican mainly driven by a certain Feelix, who did a tremendous amount of work trying to find out if grease could still be found in the bearing once removed and if oil could be found in the shaft.
After looking at many bearings sent to him by willing participants to his tests (I believe most were Boxster owners), I recall reading that:
1. He could not find any grease in any bearings he took apart; and
2. In all shafts he got and against his own initial theory, he found very little oil, as in drops amount, in them.
So, I believe Perry has a point here, but I'll leave it at that, as I don't know enough to take side one way or another.
