just got the Scosche IPFMRDS installed - Iphone integration for MOST-bus
You'll need this: Scosche IPFMRDS, cheapest place i found was http://www.sonicelectronix.com/item_...e-IPFMRDS.html
you'll need to buy the 2 adapters which come in a kit from Metra AntennaWorks, model 40-EU30. I got ripped and payed $55 cause my indy ordered it, but its $28 on amazon
so basically for about $160+ installation you can have Iphone/Ipod integration in the MOST-bus system (MY03+).
I'm using my Iphone 4. Most importantly not only does it play music/pandora, but it also charges!!! and FAST!!!! Music is great... absolutely ZERO static. My display shows a song name, but after I change it, it's still the same song name. But who cares. You control the music from the Iphone/ipad. *no "accessory connected" screen* He hid the unit behind the center console, so the only thing coming out is a wire.
This is a MUST for people like me who 1) need iphone integration 2) iphone is able to charge 3) is cheap 4) good quality 5) dont want to spend $500 for the Dension install 6) keep the original head unit, which i think is classy/matches with the car and isnt tacky like every single aftermarket head unit with ricer type lighting/etc.
With this, I dont know why ANYONE would pay $500+ for the dension.
Super Moderator
Well, I put the Dension on my Cayenne S (MOST Bus), why would I pay $500?
1) Its NOT an FM modulator so sound is better
2) All the control is done via the Radio controls and steering wheel controls so I don't have to fumble with an iPhone/iPod
3) iPhone or iPod is out of the way in the glovebox or console.
4) Songs, Playlist etc all on my Nav screen display.
5) Allows me to integrate other devices through the AUX in, such as Satellite Radio
And in my 02 (No most!)996 I pulled the factory radio and installed a double Din unit for all the same reasons
So, for the money the Scosche IPFMRDS is probbaly a good solution but the Dension and other products like it have their upsides.
http://www.amazon.com/Metra-2002-Up-.../dp/B0007WQ8VQ
honestly the sound quality is pretty good - no static, no budging in of other stations, etc. and of course, if you have $500 to spend then yes, the dension is a great buy because of all you listed above (contorlling via the nav screen, etc) but i'm on a budget so i couldnt cough it up. the adaptors are what i have linked as "amazon" in the first post, but here it is again
and i am still very happy with it. does what i want. charges + good quality. only downfall is that you have to use ur iphone to change the music, which can get annoying. but for saving $350 that I can use for something else, doesnt bother me.
also, i had my mechanic connect the power line to the actual fuse box area and ran the wires from the back over the gas pedals, so the unit turns on automatically when the ignition is on and turns off when off (just like the radio). I hid the unit behind the center console. He took off the panels put it in there and put the panels back, ran the wire out from behind so there you only see a wire. i preset the station on the radio and wallah.
I also have the scosche unithttp://www.crutchfield.com/S-ejOo7pP...l?i=142IPFMRDS and it works pretty well. Every once in a while it won't connect properly and you will have to shut off the car remove the key and start again to correct. The only down side I see to this set-up is the music isn't as loud as a CD. For the cost it's hard to beat. I have mine connected to a cradle and have my phone mounted horizontally- works gret for nav. It is also a pretty easy install. Power, ground and antenna. You will need the antenna adaptor for the Porsche ( Mercedes, vw also work). I believe I paid $15 from a sound shop. This post https://rennlist.com/forums/996-foru...ml#post9327381 has a few pics.
