A Few Updates
Really been enjoying the Cab. Thank God for the mild winter
. I washed off the yellow stuff yesterday and have had fun with a few small updates:
Custom Lloyd Matts, Porsche Racing Peddles, Griots Air horn, Scosche ipfmrds Iphone interface with Dice mount, Console self, Carbon fiber licensce plate frame and Passport Radar detector install.
![](https://rennlist.com/forums/attachment.php?attachmentid=612597&stc=1&d=1330714971)
I have always done intakes on my other cars with excellent results. I think I'll probably follow suit on the cab. Reading all of the debate has definatley caused some pause. Thinking of the fabspeed CF intake? I had a really great tune on my Mini Clubman S from Alta motorsports using the accessport. Anything similar for the 996? Much easier to plug in to the OBD port than removing the computer to be flashed.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Not sure why the pics didn't post
![](http://images5a.snapfish.com/232323232%7Ffp63564%3Enu%3D32%3A%3A%3E8%3A7%3E638%3EWSNRCG%3D3769679%3B7232%3Cnu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp63548%3Enu%3D32%3A%3A%3E8%3A7%3E638%3EWSNRCG%3D376967527832%3Cnu0mrj)
[/IMG]3Enu%3D32%3A%3A%3E8%3A7%3E638%3EWSNRCG%3D3769679%3B7732%3Cnu0mrj[/IMG]![](http://images5a.snapfish.com/232323232%7Ffp635%3A5%3Enu%3D32%3A%3A%3E8%3A7%3E638%3EWSNRCG%3D3769679%3B9332%3Cnu0mrj)
![](http://images5a.snapfish.com/232323232%7Ffp635%3C9%3Enu%3D32%3A%3A%3E8%3A7%3E638%3EWSNRCG%3D3769679%3B9632%3Cnu0mrj)
http://images5a.snapfish.com/232323232%7Ffp63634%3Enu%3D32%3A%3A%3E8%3A7%3E638%3EWSNRCG%3D3769679%3B8 532%3Cnu0mrj
Car looks great.
What is the exact mount you are using?
I recently ran my iPod interface through the back of my console shelf and have been looking for a mount exactly like the one you are using. Thanks.
Bubrubb I'm using a Dice Pass-through cradle. It was the only mount that the cable connected in the back. I purchased it from Kuda mounts. Dressed it up a bit of paint to match the interior better and added the Porsche emblem.
http://www.kudausa.com/iphone-und-ip...-50-a1556.html
Excellent.
I think I found it here:
http://www.kudausa.com/iphone-und-ip...300-a1624.html
Did you drill into the top/bottom of the console shelf to mount? Did you use adhesive?
Thanks for your insight on this. I have been trying to figure out how to handle the same setup for some time now.
Glad to help. The mount comes with two arms. Use the longer one. I used a piece of 2x2 lumber and cut it to length and painted black. I screwed the mount to the 2x2. Just to be safe I used industrial Velcro on the other end. The 2x2 will fit very snug into the console self and will not move. I considered screwing it in to the back of the self but this way if I need to pull it out, I can without any hassle.
