996 Forum 1999-2005
Double DIN NAV options/photos
Old 06-07-2012 | 06:54 AM
  #31
jackarelli's Avatar
jackarelli
Choose a pic and stick it on a USB stick. Use the USB extension cable and insert it the USB stick.
Now click on the picture of the hot air balon on the right hand side and select USB!
Find your pick and select store.
Now Select home and then theme click on background and chose your pic.
I think it can only handle upto 32gb that's why your hdd didn't work
Old 06-07-2012 | 07:15 AM
  #32
NZ951's Avatar
NZ951
Ah ok, that would possibly explain it, the HDD was a few hundred. Ill try a stick.
Old 06-07-2012 | 09:54 AM
  #33
DCP's Avatar
DCP
Originally Posted by rednerrus
hmmm that doesnt sound easy, im gonna attempt to do it myself, and ive never done it before. it might be too much for me. i think ill go with the pioneer avh8400bh.
thanks!
The blue dots don't change. I am not a fan of the JVC I bought. If I were doing it again, I would buy something else. That said, I don't think that the JVC presented any particular installation challenge. You have to be prepared to play with any installation with these install kits. The changes I described were not a big deal. The harder part for me was figuring out how to remove the horizontal divider between the OEM radio and the climate control unit. The answer for me was a grinder bit on a dremel tool to remove rivets. Be prepared to do a bit of creative thinking.
Old 06-07-2012 | 10:44 AM
  #34
jumper5836's Avatar
jumper5836
Mine
When it starts up
Old 06-07-2012 | 01:19 PM
  #35
Chomper129's Avatar
Chomper129
When it starts up
How did you manage to get the Porsche logo on the startup page? I just installed the Kenwood DNX 6960 and I could only get the logo to be the background wallpaper for the main menu. It still says Kenwood and Garmin on the startup. Any help would be appreciated.
Old 06-07-2012 | 01:39 PM
  #36
jumper5836's Avatar
jumper5836
I think this is what I did. It's been awhile.
· First connect the USB Thumbdrive containing image file.
· To enter setup Mode, press SRC+EJECT, then RESET.
· Press and hold FNC & EJECT keys, then press RESET Key.
· Release reset key, and hold FNC & EJECT Key until illumination activates.
· If you want to change the opening image to your own image (i.e., company logo), Press OEM Image.
· If you want to put original KENWOOD opening back,press KENWOOD image.
· Select the image you want to use.
· When the image is loaded, select Enter
Old 06-07-2012 | 02:05 PM
  #37
Chomper129's Avatar
Chomper129
thanks Jumper. I'll try it when I get home. One more question, do you know what size the file needs to be? I've tried reasonably hi-res files, and they still look pretty bad
thanks again for the info. Really appreciate it.
Old 06-07-2012 | 02:38 PM
  #38
jumper5836's Avatar
jumper5836
I think I used a 1920x1080 jpg. It may get resized when it is uploaded but as long as the file is the correct width and height it won't get distorted.
Old 06-07-2012 | 03:26 PM
  #39
Chomper129's Avatar
Chomper129
Thank you so much for the info! Can't wait to try it out!
Old 06-07-2012 | 03:41 PM
  #40
SacTownGuy's Avatar
SacTownGuy
Great thread. I especially like the photos of different installation options and in particular the extras. Love that one with the custom Iphone holder. Very cool!
Old 06-07-2012 | 05:34 PM
  #41
Gonzo911's Avatar
Gonzo911
Rat Balls
can you take a pic of how that looks?
Here you go.
Old 06-07-2012 | 06:41 PM
  #42
kent's Avatar
kent
Originally Posted by Gonzo911
Here you go.
very nice and clean set up.
Old 06-08-2012 | 01:05 AM
  #43
rednerrus's Avatar
rednerrus
thanks a lot. i really don't wanna pay money to get it installed, and i cant find any shops in so cal that i trust to do a good job.
Old 06-08-2012 | 11:31 AM
  #44
Chomper129's Avatar
Chomper129
rednerrus,
PM me with your email address, and I can send you some pdf files of the install process that I used. I would also highly recommend buying the kit from eurosports on ebay. http://www.ebay.com/itm/99-01-PORSCH...ht_2177wt_1126
Helped tremendously. I installed mine, and while its a bit overwhelming at first, its totally doable if you take your time with it
Old 06-23-2012 | 11:32 AM
  #45
kenmhall1's Avatar
kenmhall1
Pioneer AVH-P2400BT in EuroMotorSpeed fit kit:
Quick Reply: Double DIN NAV options/photos
