Crank Pulley Noise - Redux (engine drop)
#76
If the acetone could wash away critical lubricant just suspend the part by wire just above the dry ice in a bucket with just a few inches of dry ice in the bucket. The cold will stay in the bucket and the part will be chilly in just a few minutes.
Sincerely,
Macster.
#79
I'm not expert, but that doesn't sound particularly healthy to me. Does it pass the other tests? I would get some more input.
If the flywheel is high miles, is scored, and the springs sound unhealthy more than likely you'll be back in there sooner rather than later. If the flywheel is making unusual noises, maybe that is contributing to the problem noise you were having?
#80
#81
Still waiting for the lifters to come from Pelican, I decided to clean up the FW and pressure plate since I have a lot of life left on the clutch disc. Mated the transmission and cleaned my suspension a bit.
#82
Just got my fuel injectors in from witchhunter performance. Only $135 to refurbish and flow test all six injectors. I was surprised to see that the flow test report only showed minimal improvements.. this is because the injectors were already leak free and had good spray patterns prior to cleaning apparently. They do look like new though!!
#83
There is a TSB for inspecting the FW. You can find it with a membership over on the Renntech site, but it basically wants you to look for a relatively small deflection in each direction away from center, with a return to center when you stop trying to turn the FW.
#84
Gentlemen, I got the lifters put in the car. The engine is back in the car and I will be doing the final activities today (compressor, coolant, oil, and tensioner installation). Everything went back together very easily. The only part that was a PITA was the slave cylinder even when the engine was lowered.
#86
For next time:
Porsche TSB 1360 8/02 assessment of DMF…
The twist below must be carried out by hand and without any tools. Twist distance to be measured at the external diameter of the DMF
Can the DMF be twisted by approx.. 15mm to both left and right, and does it then return to approx. its initial position? If yes good
Can DMF be twisted beyond 15mm (excessive turn) without a noticeable increase in the spring force? Yes = bad, no = good
#87
Alright... So I started the engine today. Sounds much better after taking it around the block! The engine is much quieter after the chain guides and the lifters were replaced and leak free! Bad news: the noise coming the crank pulley is still there!!! It is obvious at this point that the noise is coming from something within the crankcase OR it is the flywheel. This car will not be getting anymore attention this year. Its a shame that I could not pinpoint the noise after all this work but my budget could not handle me going any further. In the meantime I will driving the **** out of it.
#90
"Mr RPMulli,
We were unable to externally diagnose the reason for the abnormal noise coming from your engine. We regret to inform you that in order to fully diagnose the reason for the abnormal noise we would need to completely dismantle your engine at the rate of $150 per hour at 80 hours of labor. Once the problem is identified new parts will be available for purchase at MSRP + margin, and then the engine reassembled by one of in house engine build "experts" (because we do this all the time). The reassembly will require 80 hours of labor. Because of the extraordinary cost this would incur including parts and labor, we recommend a more sensibly priced replacement engine for your vehicle, which is currently discounted at $28,000, including a non-refundable core deposit.
Sincerely,
Dr. Porsche."
Sincerely,
Dr. Porsche."
