996 Forum 1999-2005
A common, available, sealant for the oil pan?
Old 12-17-2011, 11:32 AM
RallyJon
Weathergirl
RallyJon's Avatar
Question A common, available, sealant for the oil pan?
Getting pretty frustrated here. The IMS Guardian does not come with any sealant, which is required for installation. The recommended sealant is Loctite 5900, which I couldn't find locally. I found a guy on Ebay selling it, but it came completely solidified--useless.
After waiting weeks to do this, I've got finally got a day free today to do the install. Is there any comparable sealant that's available at Pep Boys, AutoZone, etc.?
Old 12-17-2011, 11:55 AM
logray
logray's Avatar
This was a tip from Doug. Napa permatex copper loctite 5920 works great. I've used it and it works well. Be sure to only apply a 1mm to 1.5mm wide bead.
Also if you have a Porsche dealership near you they carry the best stuff (drei bond). Not sure if they would have to special order it for you. P/N 00004320373 listed as "ORMD-WINDOW ADHESIVE". It is drei bond though...
Old 12-17-2011, 12:41 PM
nick49
nick49's Avatar
Any sensor safe type RTV, Loctite, Permatex Ultra Black, Yamabond (Yamaha). Just go to the nearest auto parts store and pick up a tube. Fuel and oil resistant is best, brand is unimportant. Anything made for aluminum motors is fine.
Old 12-17-2011, 12:45 PM
RallyJon
Weathergirl
RallyJon's Avatar
Ran out to Pep Boys and they had the Permatex "The Right Stuff". Looks like a similar spec, so I'll give it a try. Thanks!
Old 12-17-2011, 12:50 PM
Dharn55
Dharn55's Avatar
VW dealers also have the dreibond. But the Permatex works fine.
Old 12-18-2011, 11:20 PM
Doug Donsbach
Doug Donsbach's Avatar
The Permatex product you mention is, as far as I can tell, equivalent to the Loctite product.
It has the same working time, squeezes out the same, and cures to the same hardness. Haven't had any issues with leaks with the Permatex.
Old 12-19-2011, 09:02 AM
Ubermensch
Ubermensch's Avatar
Mcmaster-Carr: http://www.mcmaster.com/#loctite-5900/=ffhd0b
I normally get things I order the next day since they have so many distribution locations...
-Shawn
Old 12-19-2011, 02:55 PM
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,293 Likes on 903 Posts
We sell the Dreibond separately on our site.. I would not recommend any other sealant.
Old 04-21-2012, 10:34 AM
perryinva
perryinva's Avatar
Bought Dreibond, $25 at dealership. Clear silicone gasket sealant. Original was black. Wonder why the change? Why it and no other?
Old 04-21-2012, 02:01 PM
San Rensho
San Rensho's Avatar
I just did mine today with permatex red. Be very stingy with the stuff. Just a tiny 1mm bead is best, otherwise it squeezes out into the sump and can clog the oil pickup tube.
Less is more.
Old 04-21-2012, 05:39 PM
Byprodriver
Byprodriver's Avatar
Black stuff was probably Loctite 5900, both work well but the 5900 is very hard to remove.
Old 04-22-2012, 09:27 AM
jdog
jdog's Avatar
Go get the Permatex "The Right Stuff- Ultra Grey" that is in the caulking tube style. It is specifically designed for imports and such. I called Permatex's tech line and told them the Loctite equivalent and that's what they told me to use. Has been holding ever since.
Old 08-17-2013, 12:53 PM
yank_my_chain
yank_my_chain's Avatar
All the local auto parts store had was this :
1 Oz Loctite® Stik'N Seal® Oil & Gas Resistant 1252795 - Amazon.com 1 Oz Loctite® Stik'N Seal® Oil & Gas Resistant 1252795 - Amazon.com
Should this be OK?
Also, what is the torque setting for the oil pan bolts? Should I use some type of threadlocker on those?
Old 08-17-2013, 03:48 PM
pfbz
pfbz's Avatar
Received 2,873 Likes on 1,530 Posts
Should this be OK?
That doesn't look like a good choice at all...
Your product looks more like a silicon adhesive than gasket compound, and that sort of tube is going to make it very difficult to lay down the very thin bead you are looking for.
Permatex 'The Right Stuff' is commonly available at almost all auto parts stores and is much closer to the Porsche specified Loctite 5900 or Drei-bond than that stuff, though the Loctite and Drei-bond should be pretty easily available through either a Porsche or VW dealer.
Not getting excess sealant squeezed into the oil pan and having any minor amount that does get squeezed in be very tenacious and not break loose where it can get sucked into the oil intake seems to be much more important than the actual sealing of the surfaces. Most compounds probably will seal just fine...
Torque for the oil pan bolts is very light, 10Nm. Remember to tighten in cross pattern. Yes, threadlocker blue on the bolts.
Old 08-17-2013, 05:40 PM
yank_my_chain
Thanks for the advice. I did go to another store and found the Permatex. Everything went well and found very little debris in the pan. I'm sure this was the first time it had been removed on my '99 C2 with 88K miles. Sending oil off to Blackstone for an analysis. Will post results when received.
Quick Reply: A common, available, sealant for the oil pan?
