Porsche remanufactured engine core charge
I have a cracked engine cylinder liner on my "03 911 4S and I am considering replacing it with a Porsche remanufactured engine. There is an additional core charge of $3,300 should they determine that the returned core is not useable.
Does anyone know what criteria Porsche uses to determine if the core that is sent back to Porsche qualifies as suitable and not charged the core charge?
Specifically as it may apply to a cracked cylinder liner?
pretty disappointing to read so many failures. You would think porsche knowing how many problems this engine has they would not be bothering you with the type of failure..... that is just nuts. They should have updated the engines for free if you ask me.
I would contact Jake @ http://www.flat6innovations.com/ Do some research on common engine failures for you car, you will see how the cylinders fail and how you can upgrade them You may get away with just replacing the cylinders.
Also look at this http://www.flat6innovations.com/why.htm
Good luck.
Good luck.
The Penguin King
From what I understand, Porsche is fairly liberal with core charges. My race engine failed due to a cylinder failure, and they accepted it.
In the past Porsche would take just about any core as they would have to document/admit what was wrong with the engine to reject it and they were loath to disclose the real cause of failures.
Former Vendor
I might be able to get you a better deal on a new engine as well. I have learned a lot about what these new engines need before being applied, based on tearing them down before they are ever fired up.
The cores can be tricky, really tricky and its not always a pleasant experience.
There are options and you need to explore all of them.
The latest information I received from a dealer is that the type of crack I have in the cylinder liner MAY or MAYNOT be accepted by Porsche as a useable core. Essentially it is a crap shot if I would see the core charge returned.
I like how they want the core charge paid up front
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
How many miles does your car have?
The Penguin King
Find another dealer. Seriously. There was never ever a question on my engine.
Former Vendor
Lots has changed with cores as of late.. Especially on certain cars/ models. Some people are getting hosed on their core deposits.
Ultimately until the engine gets to Germany and is absolutely accepted no one knows whether the core deposit will be returned.
Given the car is located probably a ways from me and is undrivable there's the cost of having it shipped to my house and local Porsche dealer or the trouble of having it delivered to a Porsche dealer in your area and then getting the engine R&R'd and the car back on the road.
Sincerely,
Macster.
The Penguin King
I had no problem whatsoever exchanging an engine with a cylinder wall failure just this past august. No questions asked.
