So whats in the box Beeoch? LNE IMS bearing
Getting ready to do the IMS retro fit to my 99.
I got the tool and bearing.. Not sure why the unsealed side of the bearing will point out. But I am sure it will be some appearant during the process.
Plus the lower temp thermo and a pix of our begging dog with her sorry look wanting a potato chip.
Rocky Mountain High
Did your dog have a starring role in Men In Black? I think I've seen that dog before...
Helo Driver
The second is the aluminum block to insert the bearing. When you go to pull the old bearing, insert a oiled washer between the large nut and the puller. If you don't the nut will want to gaul and make the puller turn in the IMS seal area. I also had to grind a bit of one ear from the IMS flange to clear the flywheel per the instructions.
Rick
99 996C4
87 944S
Rick
99 996C4
87 944S
