Oil Wars, Revisited!!!
#61
OMG, the reason everyone gives up arguing facts with you is that you dimiss them. Facts are just that, non-debatable. What is even more hilarious is some of the reasoning you use to strengthen your case is actually backwards and shows a total lack of understanding about viscosity and lubricants in general. I'm not upset about it, it's actually quite entertaining! Please try to present to us one factual piece of info to make your point, no conjecture.
#62
The so called oil expert of this board just can't provide good evidence to back up his belief because its based on pure personal feelings. So many people just believe that they just know better than the recomended factory fill. There are reason why places like Synergy uses different oils, mainly is that there engine are different spec than yours are. Most race shops take them apart and have different specs on tollerances which may be reasoning for this.
#63
There you go again with the attacks and again, absolutely no mention of what I stated that is not true. I know, you just like to speak in general terms so as not to commit to anything, which most probably means you have limited knowledge of the subject matter. However, there are a few people here that care enough to read about other experiences and opinions and smart enough to do a little reasearch of their own if they care too. Not everyone will or should blindly accept the consensus position. The consensus is often proven wrong.
I have already prresented the facts as they relate to 0W40 and 5W50 oils. They are facts and if you care not to accept them or not, that is your choice. They are easily verified by reading your manual and with a few clicks of your mouse or a trip to your library.
There is no need to reply (although you probably won't be able to stop yourself) since you seem unable to contribute anything constructive to this discussion.
#64
Weren't you recommending a "15" w50 just a short while ago? Why the switch? What wisdom can you share with us concerining your sudden change of heart? Why shouldn't I use a 15w50? Why 5w50? Do tell us what research and exhaustive testing led you to make this earth shattering change. Have you contacted each of the 996 owners whom you convinced to use your fomer personally approved oil? I remember debating with you about 5wxx oils. You must have had an epihany!
#65
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
#67
No credentials. No objective proof. No examples of engine failure caused by oil viscosity problems. From a man who claimed in a recent thread to have three degrees, and writes sentences like, "You, it is a big range. There is more to oil than you can learned on the internet, which some people here refuse to accept."
#68
We had a Fluid Engineer come into my work once and state that oil in a jet engine is not for lubrication, but for cooling only. Think about that one for awhile. Made one of our Engineers dumbfounded for awhile. Jet engines use gear pumps, piston rings, and friction bearings very similar to reciprocating (car) engines.
PS: Turbines do not use pistons they are just big compressors in a way that change pressure to velocity with some Jet A fuel thrown in, not to to be pompus but if your wondering I am FAA certified.
#70
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Something as simple as to following the recommended engine oil has become so high tech and complicated, I am scared to ask about bearing grease.
Maybe, just maybe this has been a tiny bit overanalyzed?
Nah, if anything this calls for the assembly of an elite car engine oil research dream team
#72
Not completly true Tippy, I used to test turbine engines for many years on Heavy Jet AC and Oil and Gas industry and many engines use different types of seals (Carbon air/oil etc) and they do carry heat away from surfaces but also provide in sealing and lubrication.
The rings I was referring to were on the carbon seals, not for compression of a cylinder like a piston.
#73
See what I mean, it is too hard to understand that oil in jet engine is for cooling, not lubrication. If the bearings stay cool, there is no need for a lubricant according to "this" Engineer. Heat is what causes failure, remember, all thrust and radial bearings in jet engines are ball or roller.
#74
Let me rephrase this. Yes, the oil lubricates and is needed to a degree, but his point was that if the bearing is "lubricated" but is too hot, it is going to fail no matter how much lubrication you have. "Wicking" away the heat outways lubrication.
#75
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
