Gas gauge show empty after battery change
Lifetime Member
Lifetime Member
Battery died this morning, after 8 years? Maybe... at least it was a original Porsche battery.
After a new battery she started right up, but now the gas gauge is showing empty. Normal?
On a C4 you will need to fill the tank - disconnect the battery again (then re-connect it) - then it will re-calibrate.
I think there is a warning in the Owner's Manual about disconnecting the battery with low fuel.
Lifetime Member
Lifetime Member
Loren,
I will give that a try today. Also I noticed that the speedometer is showing km now instead of mile. How do I switch that back to miles instead?
TIA
TIA
Chandler!
Switching back to miles can be done from the OBC, just use the stalk and cycle through the choices you'll see.
Also, if your gas guage doesn't reset, note that there was a recall on C4 cars about the gas gauge only showing 3/4 full after reset, so you might need to bring it to Porsche if that happens.
Lifetime Member
Lifetime Member
Just filled up gas and the gauge is reading properly, all without disconnecting the battery.
I think I read somewhere that the 2nd half of the tank is mesaured using calculation not with the tank float? Or something like that.
Lifetime Member
Lifetime Member
Sorry, I should have RTFM.... Too lazy... all those stupid SOPs they are making me read in the pharmaceutical business is killing me.
