996 Forum 1999-2005
K&N Filter oil spray?
Old 05-29-2010, 11:55 AM
  #31
ivangene
Parts Specialist
ivangene's Avatar
Originally Posted by Tippy
That is about the same as not running a filter at all!
The oil is the filter.
go get em Cory!!
wait, that was 3 years ago.....
go FIND em Cory
fwiw - Chao has it right
"I do and did. I ran it without oil for a while and blew out the MAF. I have been replacing MAFs every 30K miles with this setup. Then again, I don't bother to clean MAFs when I get PSM and ABS lighting up on the dash. "
its fine to run these... just know the cost !
Old 05-29-2010, 04:49 PM
  #32
chsu74
chsu74's Avatar
$156 or $217 for MAFs depending if your engine is egas or cable..
http://www.autohausaz.com/search/pro...0Mass%20Sensor
Old 05-29-2010, 06:34 PM
  #33
Tippy
Tippy's Avatar
Originally Posted by ivangene
go get em Cory!!
go FIND em Cory
Oh, didnt see the date Ed! LOLOLOL
Old 10-16-2020, 02:28 PM
  #34
georgeous
georgeous's Avatar
Default what do u clean k& n the filter with.
Originally Posted by 10 GT3
Have you ever seen a K&N filter that wasn't cleaned in 15K miles? Look at one at 6K. It is so clogged with dirt and debris you actaully get a significant loss in performance. You don't notice the loss as it happens slowly over time, but as soon as you clean and oil the filter the car all of a sudden wakes up and feels a lot stronger. I have the filters and systems on my cars to improve performance and I'll continue to follow my normal maintenance to keep it.
what do you clean the filter with and is it easy to remove and replace🤔
Old 10-17-2020, 08:13 PM
  #35
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,293 Likes on 903 Posts
I file these in the trash can every time a car comes in with one. I run the stock panel filter, and have made 480 HP with it.
The following 5 users liked this post by Flat6 Innovations:
808Bill (10-18-2020), 928FIXER (10-21-2020), JB001 (10-17-2020), petero (10-18-2020), ZuffenZeus (10-19-2020)
Old 10-18-2020, 09:49 AM
  #36
DBJoe996
DBJoe996's Avatar
Received 1,184 Likes on 757 Posts
I'm making a note to bring this up again in 2030............
The following 2 users liked this post by DBJoe996:
808Bill (10-18-2020), petero (10-18-2020)
Old 10-18-2020, 12:09 PM
  #37
AnthonyGS
AnthonyGS's Avatar
Originally Posted by Flat6 Innovations
I file these in the trash can every time a car comes in with one. I run the stock panel filter, e and have made 480 HP with it.
This is the correct answer. If you think the factory filter and airbox are holding you back, you’d be mistaken in almost every case.
Most aftermarket stuff is designed to separate you from your money and little else.
James_03C4S (10-18-2020)
Old 10-19-2020, 02:06 PM
  #38
georgeous
georgeous's Avatar
Default k& n filter oil ?
You need to re-oil it everytime you clean it. I normally clean the K&N filters on all my vehicles when I change the oil every 3000 miles. For the 996 and my SC, I clean and re-oil them every 3000 miles. If I wait and let the filter get more dirty, I can notice a loss in performance. I have cleaned and re-oiled the filter on my 996 3 times and never had a problem.
what. oil do you use for filter .
Old 10-19-2020, 05:11 PM
  #39
DBJoe996
DBJoe996's Avatar
Old 10-19-2020, 06:09 PM
  #40
michaelo
michaelo's Avatar
Originally Posted by TAILWAG
Actually this is not accurate at all. I actually had a car dynoed with a brand new filter from K&N and replaced the filter with a "dirty" one...(about 20,000 miles worth). Even though the "dirty" pull was done after the car was already warm, the car actually made 0.9 more hp to be exact...This was done on an 01 S2000 by the way...
Wow....0.9 more hp....Holy Horsepower Batman.
Old 10-20-2020, 11:57 AM
  #41
808Bill
808Bill's Avatar
K&N filter oil is what you want should you go this route. Or you can use a different brand dry filter instead.
Old 10-21-2020, 10:39 AM
  #42
Daycipher
Cruisin'
Daycipher's Avatar
Default New BMC Air Filter installed and Elbow Kit
Old 10-21-2020, 02:33 PM
  #43
Porschetech3
Porschetech3's Avatar
Received 4,646 Likes on 2,105 Posts
Here is a sound clip from a Custom short Ram intake I designed to use with the 991 sound enhancer for sound purpose only. It does use a Dual Cone K&N filter but a paper dry filter could be used as well.
I discarded the factory air box only to make room for the sound enhancer, there were not enough room for both.
The inlet air to the engine as measured at the MAF is only 1.5 degrees warmer than the ambient air temp at anything above 30mph.
The K&N filter has been on for about 75k miles and hasn't been cleaned or re-oiled.( encase you didn't know, the "dirtier" an air filter gets, the better it "filters", but if the total CFM gets less than what the engine needs it will start to lose top end power) The only problem with the MAF sensor during that time was last year I noticed the fuel trims getting a little away from ideal, but not setting a fault code. I cleaned the MAF with CRC and the fuel trims returned to ideal..
I built about a dozen of these for friends and acquaintances but got a lot of hate from some for "intake sound enhancement" ( as if it were different to exhaust sound enhancement). I actually prefer the intake sound enhancement over the exhaust sound enhancements. The car pretty much keeps the outside noise quite, while the inside noise screams only at full throttle and high RPMS.
Here is a pic of one installed on a 997S
File Type: mp3
Old 10-21-2020, 02:36 PM
  #44
Daycipher
Cruisin'
Daycipher's Avatar
That is a great aggressive look.
Quick Reply: K&N Filter oil spray?
