996 Forum 1999-2005
Random Power Loss
Old 06-26-2024, 11:19 AM
Yogibara
Yogibara's Avatar
Default Random Power Loss
Greetings all,
So I've been enjoying my rebuilt 4.0 carrera for some time now and have observed an odd behavior twice now. Twice now the car is low on power when I drive it. Then, I'll park it and come back and full power is back. So to expand, when I go WOT on each gear change there is a significant reduction of power. Even at a stop and I just rev it up it doesn't sound as powerful.
  • < 3000K mile rebuilt engine
  • new injectors
  • new clutch
  • No CEL
I've got a Durametric so if there's something I should monitor while driving, let me know. Thanks!
Yogi
Old 06-26-2024, 12:17 PM
De Jeeper
De Jeeper's Avatar
Received 3,478 Likes on 1,831 Posts
I would monitor crank position and the variocam timing angle. Not the deviation. See if they r activating? Fuel may also be an issue. Its hard to monitor fuel pressure but maybe the pump is failing. Get a gauge and start checking it.
The following 3 users liked this post by De Jeeper:
Formerly996fried (06-26-2024), TheChunkNorris (06-26-2024), Yogibara (06-27-2024)
Old 06-26-2024, 09:49 PM
jobyt
jobyt's Avatar
Did you use stock motor mounts or aftermarket? If you went aftermarket, dollars to doughnuts the ecu is picking up signals to cut power from the higher vibrations transmitted to the engine that the stock mounts would absorb.
Old 06-26-2024, 11:56 PM
Porschetech3
Porschetech3's Avatar
Received 4,676 Likes on 2,121 Posts
Easy-peasy to get on the right path if you "log" the values of TP , MAF, ignition timing, Camshaft timing, 02/AFR readings,RPM, to compare at WOT when you have the power loss to the WOT when there is no power loss...
The values that go astray will take you on the right path...
Old 06-27-2024, 01:59 PM
Yogibara
Yogibara's Avatar
No, stock mounts.
Old 06-27-2024, 02:00 PM
Yogibara
Yogibara's Avatar
Will do. I'll get my Dura out and log it. Thanks.
Old 07-01-2024, 03:45 PM
Yogibara
Yogibara's Avatar
@Porschetech3
i pulled some codes from the ecu P1235 and p0123
based on that I monitored TPS 1 and 2.
At WOT but since it’s in limp mode I could only get the engine up to around 5k rpm before I run out of runway.
RPM: 4989
TPS1: 1.25
TPS2: 3.73
MAF: 251
g 251
Old 07-01-2024, 06:10 PM
Porschetech3
Yes, the codes Po123 and P1235 point to issues with the Pedal sensor/wiring and the fuel pump controller/wiring...
I look in a bit to find the troubleshooting Tree for these faults so you can do the diag tests..
Yogibara (07-02-2024)
Old 07-02-2024, 11:58 AM
Yogibara
Yogibara's Avatar
Thank you sir!
Old 08-28-2024, 11:02 AM
Yogibara
Yogibara's Avatar
I've been bad about providing updates to issues so I want to correct that now. Issue resolved:
I wanted to give you a heads up on my electrical issue. I FOUND THE ISSUE! It was also the issue with my fuel tank pressure sensor. Check out the picture. It seems that when I put the interior back together I severed a few wires in the harness with the seatbelt bolt. The pedal position sensor wires and the 5v wire to the fuel tank pressure sensor were affected.
seatbelt bolt right through the harness.
The following 2 users liked this post by Yogibara:
JohnCA58 (08-28-2024), wdb (08-29-2024)
Old 08-28-2024, 11:53 AM
Mpfaff
Mpfaff's Avatar
Good find.
Yogibara (08-28-2024)
Old 08-28-2024, 06:51 PM
Porschetech3
Nice job Yogi on sticking with it to find the root cause of the fault codes....Kudo's to doing THE REAL WORK OF DIAGNOSING AND FINDING THE CAUSE !!!!
Wiring issues are always the hardest to find ...hard fault trouble codes can always have one of three causes.... (1) the component . (2) the DME/ECU/Controller (3) The WIRING in between !!
Old 08-29-2024, 09:50 AM
wdb
wdb's Avatar
Received 1,266 Likes on 695 Posts
This reminds me of a story told by a friend of mine a long time ago who worked as a tractor/trailer mechanic for a trailer manufacturer. While they were building the trailers sometimes wiring would get pinched and/or otherwise damaged during assembly. Their troubleshooting method was to get 4 people to stand around the trailer, apply 24 volts to the wiring, and look for smoke.
The following 2 users liked this post by wdb:
996love (08-30-2024), Yogibara (08-29-2024)
Old 08-29-2024, 11:05 AM
Yogibara
Yogibara's Avatar
"Welcome to the smoke show"
wdb (08-29-2024)
Old 08-30-2024, 04:38 AM
theblitz
theblitz's Avatar
Wow.. that must have taken some digging, looking forward to watching your video on YouTube, seems like you would have felt that when you where putting the bolt in, must have had to uga-duged it
Quick Reply: Random Power Loss
