996.2 OLD vs NEW Oil Dipstick
While reading, I bumped into a technical document that says that for 996.2 oil dipstick prior to VIN ...99Z2S603565 should be replaced and the instrument cluster should also be coded for the new dipstick, to remedy the problems of blue smoke in acceleration. I am attaching the three pages from the document I have been reading. Is this a valid advice/upgrade to do?
The update, and the New dipstick, lowers the oil level in the pan by, I believe, half a quart. This was a decision to lower the chance of smoke, and lower the chance of their terrible AOS design sucking oil into the intake, by increasing the chance of oil starvation.
If you run an UAOS, or especially with the track drain, then the consensus here seems to be to run at the Old, higher, oil level.
The following 2 users liked this post by jdbornem:
isalos (05-09-2024),
Porschetech3 (05-09-2024)
My advice if you have a 2002 with engine before 662 11805 do NOT change to the new style dipstick ( or reprogram the instrument cluster) and if you a 2002+ after engine # 662 11806 CHANGE BACK to the 996.1 dipstick ( and reprogram the instrument cluster to suit the old style dipstick and oil fill level)...
The change was due to an inefficient AOS system and the change was just a band-aid( equivalent to sticking a band-aid over a bullet wound ), new style dipstick and oil fill level increases the risk of oil starvation.
The much better and safer solution is to install the UAOS Sytem, it is a much more robust and efficient AOS System that has many many benefits...
The following 6 users liked this post by Porschetech3:
allcool (05-09-2024),
GC996 (05-10-2024),
isalos (05-10-2024),
sdematt (05-09-2024),
wildbilly32 (05-09-2024),
and 1 others liked this post.
Skip any idea if you can change it with a regular durametric or do you need the PWIS? Don't know if it really matters since I check it by the oil stick. But why not change it of you can with a durametric.
Yesterday I looked at my dipstick and it is the new style. My oil tank is at 50% and the dipstick shows that. Additionally my dashboard oil checker shows 3 lines from the top. PIWIS should that my cluster is the OLD style. so i switched to new on the PIWIS 3 (as shown on the screen above) considering that I had the new style dipstick, and now it looks overfilled... So I switched it back to OLD style and I am going to leave it there, as per the advice of everybody.
Easiest fix to make the engine happy and you happy is to replace the OEM AOS with the UAOS Track version which can handle the oil at full and even 1 qt over full. This means you can canyon carve all you want, park on a hill and even not worry if you accidently overfilled the oil, all without having to worry about smoking.
UIDS oil fill level 9.9 qts
UIDS with UAOS Track Version 10.9 qts
UIDS with UAOS Track Version and verified less than 80 LPM blow-by at WOT.... 11.4 qts to 11.9 qts
The preferred dipstick to use on ANY M96 ( and comes from the factory on all up to mid 2002 models) with UAOS is the 99610701454
The following 3 users liked this post by Porschetech3:
