996 Forum 1999-2005
replace sway bars
Old Apr 11, 2024 | 10:18 AM
Makoto0406's Avatar
Makoto0406
Default replace sway bars
I'm planning on doing a front suspension refresh. Pretty much going to be doing FCP euro control arm kit minus the steering side of the tie rods and adding the sway bar links
Couple quick questions
1) I'm planning on doing just the front. I assume I can delay the rear?
Rear seems more involved. Obviously I'll get an alignment etc
2) the Blisten control arms are on sale. Are these better/same compared to TRW Mayle
3) since I'll be changing out the sway bar links should I change out the sway bars as well? Doesn't seem like a normal wear and tear part
This is a 2000 C4 Cab daily driver that I'm trying to tighten up a bit while maintaining comfort. Occasional spirited driving
M
Old Apr 11, 2024 | 11:31 AM
De Jeeper's Avatar
De Jeeper
The sway bar is not a wear item but the bushings in the attachment cups are. Your dealer can get u the part number based on your vin. There r many diffent diameters (sometimes u can read the part number on the bushing). The only reason u would change the bar itself is for more/less roll stiffness.
Old Apr 11, 2024 | 09:14 PM
Makoto0406's Avatar
Makoto0406
Thanks Da Jeeper. I'll see if FCP can figure out the bushings. They are only around $20 seems like a no brainer.
Old Apr 11, 2024 | 10:33 PM
De Jeeper's Avatar
De Jeeper
They wont.....call the dealer with the vin and get the correct part #. They r also pretty cheap through porsche.
Old Apr 30, 2024 | 10:54 AM
GC996's Avatar
GC996
Originally Posted by irontmp
I'm considering doing a sway bar install on my 2018 RS5. Specifically the 034 Motorsport Dynamic + sway bar kit that includes front and rear bars. Wanted to see if other RS5 owners were doing front and rear sway bars or just replacing the rear only? My car is a daily driver and may see the track 2 or 3 days a year at best. If you did replace your sway bar/s how did it change how the car drove under normal driving conditions? I'm not looking to make my car so firm that is becomes uncomfortable on my daily drive. Thanks for any feedback you can provide.
What makes you want to enhance your sway bars?
Old Apr 30, 2024 | 01:58 PM
De Jeeper's Avatar
De Jeeper
Also whats a RS5?
Old Apr 30, 2024 | 02:04 PM
theprf's Avatar
theprf
RS5 is an Audi coupe with a V8, spiritual successor to the VW Corrado.
Old Apr 30, 2024 | 04:36 PM
GC996's Avatar
GC996
RS5 is a meaty performance driven version of the Audi A5. Engine, brakes, suspension, aero, interior etc is enhanced versus the S5 and A5 base models. Quite frankly, there is no need for replacing the sway bars unless you are an experienced driver on the track and you are doing the entire suspension for that purpose. Sure, you can do it if the money is burning a hole in your pocket, but most folks won't ever need it for street driving.
7 Porsche Models That Have Aged Like Fine Wine
Old May 8, 2024 | 09:07 PM
xThundersZ's Avatar
xThundersZ
Default Sway bar
Just get a front eibach sway bar and call it a day. That would enhance your driving cornering already. Leave the rear alone
Old May 8, 2024 | 09:54 PM
GC996's Avatar
GC996
Other way around. If you want better turn in amd less understeer, tighten up the rear and loosen the front.
Old May 9, 2024 | 03:33 AM
hardtailer's Avatar
hardtailer
Circling back to OP's topic:
-You can delay the rear.
-In order of quality (imho): 1. TRW 2. Meyle 3. Febi (short for Ferdinand Bilstein, not to be mistaken for Bilstein, the shock absorber manufacturer owned by ThyssenKrupp nowadays).
-as noted in earlier posts, no need to change ARB but to the ARB bushes.
Old May 11, 2024 | 08:01 AM
Makoto0406's Avatar
Makoto0406
thanks. I ended up changing out all the control arms, tie rods, drop links and bushings both front and rear. For me the front was way easier but YMMV. It’s getting an alignment as we speak.
Based on a quick test drive it made a big difference. The whole shebang was $1100ish so very much worth it. I went with a mix of manufacturers as that was what was available
M
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
