Brake Feel
Brake Feel
I have a 996.1 in which the brakes feel rather weak. The car does stop, but in order to do so you really need to press the brake pedal hard. I recently had the brake fluid flushed, and installed new pads and discs. I was hoping that would fix the issue but it has had almost no effect. I recently drove a 986.1 and the pedal feel and braking in that was significantly better. Any ideas on what could be causing it?
Brake pads vary greatly in terms of required pedal pressure and gripping force. they are always a compromise with rotor wear as well as a consideration. I have Ferodo DS2500s. They have great pedal hardness and excellent stopping force and heat resistance, but at the likely expense of shorter rotor life.
If you replaced with OEM pads and rotors, you should have the same feel as your previous pads. As suggested above, I would suggest that you have some pad glazing and/or disc break-in issues.
JRitt@essex (08-29-2023)
Out of curiosity, what rotors and pads did you use?
You may need to bed in your new brakes. There is also an outside chance that you may have a caliper or two that needs to be rebuilt. With the cars and calipers being 20+ years old, it's not uncommon. Your indy can take a look and tell you.
JohnCA58 (08-28-2023)
In your case you can put the above hints about bedding in new pads on the back burner.
With what you've done you would have felt a difference at the first braking you did with them.
Since you don't, the cause lies in something you haven't changed (yet): the brake booster as mentioned before and/or the calipers.
I bet the pistons on the outside of each front calipers are stuck and you only brake with the inner pad.
Overhaul the front calipers and try again. Repeat at the rear.
Thank you everyone for sharing your thoughts. The pads are OEM, haven't used them much so far as I was conscious of not wanting to glaze them. Hoping that is the brake booster rather than having to overhaul the calipers too
Thanks again
Thanks again
In most cases, just driving around town with plenty of starts or stops will bed them. Especially since it looked like you replaced both pads and disc's at the same time. Bedding becomes more important if you are just replacing pads or just rotors because you have uneven ridges that develop and depending on what you replace will make it important to get the old part to wear into the new part. This is why when going to a dealer for a brake change, they replace both pads and rotors at the same time. It's easier for new pads and rotors to match up quicker than replacing just pads and keeping the old rotors.
As a side note, there hasn't been a time over the past 21 years when I replaced my rotors, or just pads, or both at the same time that it didn't take a little bit of braking to get the brakes "grippy" on my 996.
Talk to your Porsche Indy and see what they say.
It's curious that the problem appears just after replacing the pads and rotors. Do I have that correct?
It could be a booster, but I am inclined to asked what suddenly changed and having serviced the brakes and flushed fluid (replaced or simply bled?) at the same time would raise a flag for me.
Sure, it could be alot of things.
But to your question on new rotors and pads, as I write this, I just received a new set of rear Brembo rotors 345x28. Still waiting on fronts. Pulled them out of the box and they are smooth and slippery as you run your hand over them. All I need to do is put them on and have a little fun with braking to transform them. As the abrasion occurs, they get grippier. I'll take a picture and post.
Used Brembo
New Brembo with smooth finish.
Used Brembo
GC996 (09-05-2023)
Actually the brakes always felt weak. I had the brake fluid flushed and replaced the pads and rotors hoping for an improvement, but so far they don't feel any different. I would characterize it as the brakes just feeling dead, like there is no bite
I would watch the bedding in video and go find yourself a big parking lot that you can get some abrasion on your rotors from the brake pads. You will get more brake grip after going thru the process and it may help and or confirm its more than being new oem pads and rotors. Besides, it doesnt cost you anything. You can also eliminate boiled brake fluid since it was just changed. I would just look for leaking brake fluid as a step.
Then the next step is talk to your indy to see what they suggest as next steps with other parts.
One thing to consider, depending on what you drove before the 996 and it's braking feel, will influence your opinions on oem 996 braking feel. It may be as simple as getting some more aggressive brake pads which will give you more grip immediately. But will also give you more brake dust. It's a tradeoff.
I have driven several different vehicles of the same exact year and model and sometimes the brakes feel different from car to car - one feels super grabby and the other requires a lot more force from your foot.
