Driven DI40 / DT40 & pca Video
#151
I'm not very happy with DI40 0-40. Tried in in our 17 Macan GTS before changing my 991 over to it, and i have to say valve tapping is loud. Much louder than LiquMoly, Schaffers or Mobil One. Not sure I want to try it in cartera now.....
#152
DI40 has worked well in my 996.2. My 3.6 seems to like it on the street and track. Engine seems to run quieter, especially during cold start-ups. I plan on trying DI50 next to see it's effects on oil pressures on the track. So far its been a winner.
#154
This thread has convinced me to change from DT40 to DI40 next oil change for my 996.1. I usually want the best oil regardless of price, but DI40 is getting up there. I'll probably FCP it for their oil return plan. Never did that before, because I just don't think it's fair to return oil, but I guess FCP has found a way to make their policy work. I'll buy everything else there also, which I guess is part of their plan.
#155
#156
At $225 a case, anything adds up. Not cheap oil.
#157
Here is what I will be running in my diesels in place of DP40:
https://lnengineering.com/products/s...-1-gallon.html
wdb (04-30-2024)
#158
It was discontinued due to lack of demand.
#159
plpete84 (04-30-2024)
#161
We've tried it a few times where customers did not break in their engines properly or they had fuel injector issues that led to high oil consumption. After a few thousands miles of running the Cummins Restore oil, consumption was greatly reduced and crankcase manometer vacuum readings were improved.
plpete84 (05-09-2024)
#162
Having ran this oil for a short OCI, keep in mind that you don't want to push the car too hard with it. 30 weight will cause some lower oil pressure. Nothing to be concerned about but it won't be as good as a 40 weight and definitely 50.
#163
Here is the virgin analysis from the SDiax website for reference (bottle looks slightly different but i believe it is the same product):
#164
Thank you and thanks again for the info! I am going to try this in a Audi 2014 Q5 2.0T for my next OCI. The OCI likely will be a lot of highway driving and I never bang on this car that hard. I will run it for 3,000 miles and will change the oil filter mid-way at 1,500 miles. Then I will immediately switch back to DI40. Since I am only running this in the summer I am not concerned it is a 10W and about the hot viscosity you are right, this is not an oil you want to run long or hard -- 1.7 cSt @ 100C, thin as water haha
#165
FWIW, talked to Driven the other day about the difference in formula for DI40 and DI50. Same formula but more viscosity in DI50. They also said that as a result, there is no conflict in formula if you decide to run DI50 in warm months and DI40 in cold months.
wdb (05-10-2024)
