Mythbuster: Are the early builds ‘special’?
#47
My 2015 Cayman GTS came with PTV and Option 220 LSD
I checked my 2017 Porsche GTS. Check here: https://www.stuttcars.com/porsche-91...options-codes/
We also can see Option 220 is indeed now called PTV Porsche Torque Vectoring , and there is Option 221which is PTV+ Porsche Torque Vectoring Plus, provides controlled rear-diff. lock in addition to PTV.
I rest my case, however flimsy it may be.
#49
#50
They are not actually.
Even if you want to consider them "special" because they were manufactured together with the 993 (even all the 996 after were also produced in the same line), as you can read in that piece of text, that was just until early in the year 98, what applies for MY98 cars (second column in the table)
Model year for the 996 changed around July, meaning that most of the US cars that you see in the US as manufactured in 98, are in fact, MY99 (they will count in the third column) and there is nothing special in those numbers.
Special are definetely the first 14 MY97, and the MY98 if you want, because is the first full year of production and because is the year with less production, but none of them made it to the US (where they started to arrive in MY99 format, meaning manufactured from mid 98 to mid 99)
#51
They are not actually.Even if you want to consider them "special" because they were manufactured together with the 993 (even all the 996 after were also produced in the same line), as you can read in that piece of text, that was just until early in the year 98, what applies for MY98 cars (second column in the table) Model year for the 996 changed around July, meaning that most of the US cars that you see in the US as manufactured in 98, are in fact, MY99 (they will count in the third column) and there is nothing special in those numbers. Special are definetely the first 14 MY97, and the MY98 if you want, because is the first full year of production and because is the year with less production, but none of them made it to the US (where they started to arrive in MY99 format, meaning manufactured from mid 98 to mid 99)
WingsWheelsHulls (10-24-2023)
#53
I don't completely follow the my97 my98 my99 determinations maybe you can explain that to me. I know the US didn't get them until 1999 about all i know i thought all the US cars were MY99 just because of the year they're titled/sold new but but mine was built in late 97 completed tagged jan 98 , is it still an MY99?
The following 2 users liked this post by gbarron:
Garage19builds (10-24-2023),
hkovalcik (10-25-2023)
#54
Could it be the people that own them find them special and the rest of us….. not so much ?
TheChunkNorris (10-24-2023)
#56
I need to understand if enough “unique “ things that are different from the cars that followed or preceded it
Dont make it special what would ???
my early build 6/98 has a factory aero and one year only color glacier white and space gray interior
I’ve only seen one car in over 20 shows that came close to mine but was missing the aero package
#58
EVOMMM (10-25-2023)
#59
sept 98 build
aerokit
no rear wiper
no obc
no traction control
no rear wiper
just too bad it has a sunroof!
#60
