996 Forum 1999-2005
Ultimate Integrated Dry Sump UIDS v2.2
Old Jun 20, 2025 | 09:33 PM
  #1006
Porschetech3's Avatar
Porschetech3
Originally Posted by CTGTC
I’m planning to buy the UIDS. Two questions:
1. Is the version listed on LN’s webpage the latest and greatest version?
2. How sophisticated is the install? Debating whether to do this myself or pay a shop. I’m fairly handy (just did suspension, bleed my own brakes, change pads/rotors, etc.) but it seems like a small error here could be potentially catastrophic. Saw at one point some discussion about an install video. Did that ever come out?
Yes of course it is the newest design, I haven't been able to think of a single thing to improve on in over a year but the Patent is still Pending. The USPTO did say they would give me/UIDS special privileges/rushed service due to being a Senior Citizen and over 65 years old....lol...I guess they have had a few "die waiting" LMAOO
The install is very very easy , and why I haven't taken the time to make a video...Just drain the oil ,undo the 13 sump bolts, 4 swirl pot bolts, 2 pick-up tube bolts, ( old stuff is now out of the way ) Then install the up-pipe (2 bolts) the 997 return tubes (2 bolts) the baffles (2 bolts) , adjust baffle depth using the Precision Depth Gauge and tighten, install the 2 blue guide pins, install the O-ring on the UIDS using Vaseline to keep it in the groove, push it up into place and install the new 13 bolts,drain plug, and plug for the Oil Temp Gauge port or install an Oil Temp Sensor .. refill with Oil.. Done in about the time it takes to read this....lol
It is WAY faster than a UAOS install.. Do you already have that ???
Old Jun 20, 2025 | 10:54 PM
  #1007
tommelton's Avatar
tommelton
Skip - so you are now using the 997 oil returns vs the aluminum plate diverter for oil return? We discussed that when I bought mine, and at that time, you thought the plate was better that the 997 oil returns.
-Tom
Old Jun 21, 2025 | 12:09 AM
  #1008
Porschetech3
-Tom
Hi Tom, yes the Aluminum deaerator plate was an improvement over the 997 return tubes on that baffle design, then I envisioned a "hooded deaerator plate" that rivets to each baffle over each of the Twin Tunnel Ports and in doing so needed to go back to the 997 return tubes to compliment it ..
A small improvement in the performance but I can't stand having a new idea without implementing and testing it , and it is totally easily retrofitable as with all the UIDS improvements from day 1..
Its like going from a 2024 Porsche to a 2025 Porsche , there could be some little changes
Old Jun 21, 2025 | 10:31 AM
  #1009
CTGTC's Avatar
CTGTC
Yes I had a UAOS installed by a shop as part of an engine out job with all the standard “while you’re in there” bits.
My main concern is getting the right type and amount of sealant on the pan. Read a lot on here of even shops screwing this up and sealant showing up in oil samples and clogging the returns.
Old Jun 21, 2025 | 05:32 PM
  #1010
Porschetech3
Yes the UIDS is fully O-ringed
No leaks
No time consuming mess to clean
No risk of silicone stopping-up the oil flow
No silicone contamination of the oil samples
The main design objective of the UIDS is to stop oil starvation in long-high G turns....That achieved next objective was more ground clearance than 2 qt deep Sumps,,..Then next was " Fully O-ringed".....Slapping Silicone between two parts is the "cheapest" way to seal them but not the "BEST" way ...
Old Jun 21, 2025 | 05:44 PM
  #1011
CTGTC's Avatar
CTGTC
So no sealant required? Did not know this. Game changer.
Purchased. Will do myself. Thank you PT3 for your efforts in keeping these cars alive and thriving.
Old Jun 21, 2025 | 06:08 PM
  #1012
allcool's Avatar
allcool
No leaks
Any chance I could buy a o-ring or 2..? Are they 1 piece or super glued ends together..?
Old Jun 21, 2025 | 06:40 PM
  #1013
Porschetech3
Yes of course I have 40 of them on hand....
They are Viton ( best available for high temp oil )
VOR-N70- 103x13.950 They have to be special ordered from PSP Seals.....I buy them in batches of 50...
They can be reused many times until they lose elasticity ( takes years) as long as it doesn't get damaged in handling....
Just send me your E-mail and I can send a PayPal Invoice..
Old Jun 21, 2025 | 06:55 PM
  #1014
Porschetech3
Correct !! No Silicone Required !!
I should advertise that....lol.. That and the shear beauty of the UIDS is what people like most ( performance aside) ..
You're Welcome and Thank YOU !!!
Old Jun 22, 2025 | 05:11 PM
  #1015
Mike Murphy's Avatar
Mike Murphy
Boom.
Old Jun 23, 2025 | 12:10 AM
  #1016
Porschetech3
Originally Posted by Mike Murphy
Boom.
Yea, I keep forgetting that a lot of people like the UIDS because it is fully O-ringed , has Oil Temp Sensor Port, has Cooling Fins, Increased Ground Clearance , and is Sexy A/F !!!
And some just want to pull 2-G around the corners....
Old Jun 23, 2025 | 09:16 AM
  #1017
plpete84's Avatar
plpete84
Had a cool experience Friday seeing UIDS at work. Going at a medium speed into a pretty sharp and long right handed sweeper, RPMs were only about 3k, and was not going fast but saw the oil pressure siting 3.5bar. About a second or so into the turn I saw the oil pressure just jump up to ~4.7bar as I assumed the piston in the UIDS switched to the other position where the oil was at the time during the turn. Very cool seeing the technology at work. I was running 5w50 at the time.
Old Jun 23, 2025 | 11:47 AM
  #1018
CTGTC's Avatar
CTGTC
Can you provide more information about the oil temperature sensor port? Was unaware of this as well.
I have purchased an oil temperature sensor integrated into the drain plug, but this is suboptimal as I can no longer use a magnetic drain plug (although I still have a filter mag on the LN canister filter). What types of temperature sensors does the UIDS port accept?
Old Jun 23, 2025 | 02:58 PM
  #1019
Porschetech3
On the Bank 2 side the UIDS is drilled and Tapped to use a 10mm AIM Temp Sensor for Data Logging or just reading Oil Temps..
I chose the 10mm spec because the AIM Temp Sensor is the most popular, and 10mm is the smallest diameter and can be drilled and tapped larger for other Sensors types
In Fact 10mm and 1/8 NTP are so close you can convert between the two without drilling,, just re-tapping ..( one is tapered and one is not )
The UIDS comes with a Black Annodized 10mm Plug and seal if not using an Oil Temp Sensor...
Old Jun 25, 2025 | 01:25 AM
  #1020
dcsjc's Avatar
dcsjc
Love this thinking ahead and flexibility
