Installation guide of the PCCM Plus
#286
You might be right. I looked closer on the wiring diagram and my yellow C1 connector has one line that I could not crimp to anything since the cable seemed to be gone and that is the red/black 12V+switched cable that originally should go to the Amp. I dont know what the previous installers have done to it but will see if it is to be found at the amp connector in the trunk.
Because by my logic the amp should then get the signal from the PCCM when to start not from ignition?
#288
No Backup camers for the PCCM1 Need an aftermarket one to add bu camera
#290
Any luck? Same boat, out $500 in labor costs, 2 Porsche dealers have no answers, and I have no stereo. 2002 Carrera w/ non-MOST Bose.
#291
Hey Guys,
I'm anticipating putting a PCCM plus in my 2004 996T - which has the later PCM2.1 Double DIN with CD Player... So i know for the install i dont have to worry about a few steps, but from reading through pages and pages of installs, i'm just wondering if it will be somehow 'plug and play' without all the little nuances everyones having to deal with with converting from older single din units etc etc?
Should i attempt this myself, or just leave it up to a professional? I'm new to this, so does anyone have a straightforward video or proper DIY guide for cars with the later double din?
#292
Hi all. Just installed the PCCM+ in my 2003 Turbo. I'm pleased to say that with ample research and pre-reading, it was a pretty straightforward install. I have Bose but did not need to do anything with the amp. Being a US car, I just plugged in the MOST box and I was set. I did not opt for maps so I did not install the GPS antenna. Likewise I skipped the external microphone based on what I read about internal vs external microphone sound quality. I modified my DIN1 frame to fit, and that was the only part that wasn't really covered very well. There is a YouTube video where a guy does a similar install, but I did it a little differently and am happy with the results.
I am having one very minor issue that is just an annoyance, but I'm hoping to figure out how to resolve anyways. That is that the language appears to be UK English and the date format is DD/MM/YYYY rather than the US style of MM/DD/YYYY. I see where I can change the time format between 12/24 hours, but nothing for the date format. Likewise, I can only choose from English or French in the language settings. I've poked around in the hidden menu but couldn't find anything relevant. Has anybody else encountered this and/or figured out how to change it?
#293
Sometimes sound and sometimes not!
I have a problem that I haven’t read anywhere about yet. And believe me I’ve searched. Installed my PCCM+ a few months ago and haven’t got it to work properly due to a lot of small problems. Thanks to this thread I now only left with one problem. 2003, C2, Bose, Most.
When I listen to music the sound cuts off after a few minutes and later starts again. Sometimes when I put on the PCCM+ sound doesn´t even start at all but then after 5-20 minutes starts without any notice and then again cuts off after five/ten minutes, and this repeats itself (mostly off thou). Feels like some sort of electrical fuse/over heating issue (not even warm). The unit seems to work fine so the problem must be with amplification. No difference if it is Spotify, radio or anything else. Don´t see it being bad wiring either since it is either on or off. No difference if the car is moving or even engine on.
Any suggestions are most welcome.
#294
#295
Did you check the CAN/AMP setting in the PCCM? Given your car spec, this should be set to "CAN". Your problem sounds somewhat similar to mine (everything worked fine except for the unit shutting off every 15-20min, regardless of input type). Switching that setting to CAN solved it for me and everything works perfectly fine now
#296
#297
I’m in the car now and after about five minutes i got Dio. So why the cutouts?
#298
Thanks for the reply! Sadly the first thing I did was to throw out the PCM. But you are right of course, it should be plug and play. I would hope that the amplifier have some sort of electronic fuse or that the optic converter had something similar.
#299
Sure I checked that everything was working when I bought it. But now in hindsight not that much since I bought it late autumn and had a few projects to look forward to during winter. Not my first 996 or even 986.
#300
